Charles Adams
Flight distance : 3821312 ft
My primary use case is flying at the lake (over water). And to be honest, I've had a great deal of anxiety when I fly. But unlike other unfortunate individuals in the forums who have lost their sparks, I've not had any "close calls" with losing my spark, and I plan on continuing to fly over water. My confidence is increasing and my anxiety is decreasing.
That being said, here are some personal guidelines I follow (or real guidelines listed in the manual):
1. Don't launch until you have confirmed that you have gps lock AND that you are not receiving any compass issues. So many forum posts are about flight difficulties which started with ignoring compass warnings or getting gps errors. Just don't do it, especially when flying over water.
2. Always ensure that your home point is set. Either by waiting for the craft to establish the home point or by manually setting it. But don't rely on home point...
3. If you are launching over water (from a boat), do NOT rely on home point for returning to home. Your boat may drift from the original home point location. Home point is still important to set (if for any reason the craft decides to execute an RTH, it's still going to be close). Another reason RTH may be a poor choice for you to rely on is if you move your location over water (drive the boat around). Instead manually land your craft at the desired landing site.
4. I personally do not wait for 30% battery warning when flying over water. I return home when battery is between 40-50%. I know that is a LOT of battery and a few more minutes of flight time that one is giving up, but if you are landing on a boat (potentially a moving target), you will want that extra time for safety. If winds come up or if waves hit and push you around, you will have lots of battery life to use to abort your landing and to try again.
5. Don't fly low and close to the water (and this is from the manual). This can cause issues with the spark's vision system. Fly well above the water. I'm usually at 20' or higher. I may come lower for close up shots of my target, but I will raise back up again.
6. Be very careful about the flight environment. Low winds, good weather.
That's what I do, and I've never had an issue.
