Jose Ramos
Flight distance : 72825 ft
Portugal
Charles Adams Posted at 2017-8-29 04:48
Yes, whether or not you are moving the gimbal, the spark camera will be more susceptible to movement along the x-axis. Along the y and z axis the gimbals will compensate. Along the x axis the software will attempt to compensate, but that won't be as effective as the mechanical compensation.
Caveat: Were you flying in what you would consider to be slight winds, moderate winds, or excessive winds? The spark should perform excellent video and photography in slight winds. If you were experiencing this behavior in what you deemed to be slight winds, then I would say this is a defect. If the winds were heavy, then this is not unexpected (this drone is not as robust as the more expensive drones when compensating for high winds while recording). "Moderate" becomes more subjective.
Hi Charles,
Well, I don't know the exact wind speed at that time, but that area is well know for strong winds, being chosen by windsurfers for practicing. There were not very strong gusts of wind, but it was moderately windy. Perhaps around 20km/h - 5 meters/second. To give you an idea, with the Spark in normal mode, moving it forward with the RC stick all the way forward it was moving slowly and sometimes it drifted quite a bit to the side.
What do you think? |
