fansb885c69e
Flight distance : 349419 ft
When I first did the firmware update everything worked fine as far as the download went. I have had the usual spate of problems no map(fixed), IMU needs calibrating(not fixed), Jerky flight (not fixed), camera shuts off (not fixed), etc. I decided to check on assisant II and do a reinstall. When connected it showed I again needed to update the firmware. I did the update and realised I needed to update with all my batteries and originally I only had done it on one. I had not seen anything in the updates about this. When I use two of the batteries I get the IMU warning on the other its fine. I'm just throwing my experiance out there. I don't trust my drone anymore on flights, (I live with a lot of water). I can only wait and see what is going to happen with a fix on the other side. I have tried every fix I could find.
