After reading the manual for the P4P, I noticed a distinct lack of guidance for care and cleaning of the drone, RC, and related items. Even though they mentioned several times that one should keep the sensors clean, but not explaining how that should be done. Neither did they mention the other obvious areas like the camera lens, plastics, and moving parts. However, one can assume that you should not use caustic solutions and abrasive materials of any kind. Obvious enough, however, what do you use? Mild soap and water is the most likely approach, however, even water is bad for many of the components of these systems. I searched the forum, the best I could, and I mostly found results where folks discussed cleaning their lenses, which is important. In this case, I think you should use quality camera cleaning materials and lens cleaning solutions that are safe for coated lenses.
After you answer the 'Poll' question, please comment below and share how you clean, what you clean, and the materials you use.Survey question:
Do you clean your Drone, RC, and lens?
