I2 with CrystalSky and GPS Module for Remote Control
2242 18 2017-8-29
canistraccioil
Hi folks!
I've mounted the CrystalSky with its mounting bracket on the remote controller.
I'm wondering whether I do need to install the GPS Module for Remote Control too, since CrystalSky is equipped with GPS/GLONASS.
Anyone may help me?
Thanks
Ciao
Paolo
2017-8-29
DJI Elektra
It depends on the way you use. Please tell me your requirement, so I can have a better reply.
2017-8-30
canistraccioil
DJI Elektra Posted at 2017-8-30 03:58
Hi Elektra
Before to buy CrystalSky, I used the remote controller connected with standard mounting bracket and iPad 10". The GPS module for remote controller was installed on the top of the iPad bracket.
When I received the CrystalSky and its mounting bracket for remote control, I asked myself whether I should install also the GPS module for remote controller.
Yesterday I got the answer: yes, it is required otherwise the return to home can't be set to controller's position.
Therefore I fixed it on the middle top of the CrystalSky: is that correct?
Ciao
Paolo
2017-8-31
DJI Elektra
You are right. If you want to set controller's position as home, you should buy the GPS module.
2017-8-31
canistraccioil
DJI Elektra Posted at 2017-8-31 01:27
got it! than you!
2017-8-31
canistraccioil
I did some further testing over this subject, and I found that the situation is much more complicated than expected.
When CrystalSky is connected to the Remote Controller with GPS turned off, the embedded DJI GO 4 app acquire the GPS data coming from the external GPS Module for Remote Control (you may see the blue dot on the map), but somehow the DJI GO 4 app can't use these information to set the home point to Remote Control position: it says the GPS signal is weak and position cannot be recorded (but it's not true, the signal is strong and position is fixed, you may see on the map on the left bottom on the screen).
So I removed the GPS Module for remote control and enabled the GPS on CrystalSky.
This time I could set home point to remote control position.
So my question is: why CrystalSky doesn't correctly manage the information coming from the GPS Module for Remote Controller?
2017-9-1
DJI Elektra
canistraccioil Posted at 2017-9-1 01:13
Did you open the selection of dynamic home point?
Please enter the attached interface and slip to the left. Make sure that all the setting is done.
2017-9-4
canistraccioil
DJI Elektra Posted at 2017-9-4 03:33
Hi Elektra, I did that. I confirm you that all the settings are done correctly.
2017-9-5
fans4f8954b4
Flight distance : 18275925 ft
I think that by default the CS like to work with the new controller cedance, without GPS problems like you met.
2017-9-5
DJI Elektra
canistraccioil Posted at 2017-9-5 07:34
Can you send me the screenshot of the weak GPS signal warning?  Please tell me the info of version likes, app and drone. Thanks.
2017-9-5
Vjelovic
Croatia
Same here, exactly the same problem.
2017-10-13
DJI Elektra
Vjelovic Posted at 2017-10-13 06:51
Vjelovic, please follow the advice in 7# and ensure all the setting is done. Then if the app show weak GPS signal, please try to change an environment and try outdoor.
You can move your RC and see if the H point in the map move, too.
Keep us updated, thanks.
2017-10-13
Segami21
Flight distance : 57749 ft
Hi, so I just received the CS Ultra and noticed a weak GPS signal strength. so what is this module that I see you discussing. and does it increse the signal strength. Sorry if this is a dumb question but I am learning.
Thanks
Peter
2018-1-30
AvatarAir
Flight distance : 150932 ft
There are no settings on this screen shot.
My understanding is that the CrystalSky has built in GPS? But I do not have the Dynamic RTH function anywhere. And I have only 2 RTH icons, not 3. The standing man and triangle. I don't see a way to turn off or on GPS. Help, please. Thanks.
2018-4-24
DJI Elektra
China
Hi, there. CS has built in GPS module. But if you want to use Dynamic RTH function, you need to add this module for now. Also, the system of CS should be V2.4.2.0 or more. The feature will be optimized in the feature so that users can use Dynamic function without adding GPS module in CS.
2018-5-4
mt_flyer
Flight distance : 207822 ft
4#
want to add B4Ufly, Kittyhawk, and Airmap app... How do I do this
Can I also add google maps?
How can I tell if the built in GPS is working?
2018-5-29
mt_flyer
DJI Elektra Posted at 2018-5-4 02:31
add "this" module...what is this module
2018-5-29
AvatarAir
mt_flyer Posted at 2018-5-29 13:03
The GPS module for CS.
2018-5-29
marctronixx
Flight distance : 210118 ft
Miss DJI E,
Any update on this? has the firmware now been allowed to use the CS's gps without the need for the extra gps module? or does one still need to use the external gps module ? using CS with a Cedence.
6-29 20:19
