Is anyone else having issue with active track or tap to fly not being available and message that appears on the screen is "gimbal not installed"? Resseting didn't help and software is up to date.
I have attached a screen shot of the issue.
Support is going to have you downgrade/upgrade/refresh your firmware and do a clean re-install of your app, so you might as well try those before opening a support request. Good luck.
Like Machina mentioned, had you upgraded the drone's firmware? Please update first. Besides, please check if the "gimbal not installed" will also exist on the app's transmission interface. And I saw an N/A on the SD card info, check the SD card, try to format it. Also, please if the anti-drop hooks are mounted properly, you can refer to our tutorial:
Keep us updated if case persists. Thank you.
Thanks for the information. So I have the latest software and I have tried reinstalling software and that didn't help.. message does not appear in the app's transmission interface and hooks are mounted properly. The SD card error appears on every time.. it would record for 5 min and then message apears "Card error, please replaced it" but still records with no problem... have tried formating and using different sd card but issue is still there with card and gimbal... I didn't notice that two appear at the same time but rather at diferent times...
fans607b5fee Posted at 2017-8-31 02:47
Thanks for your feedback. Could you please provide us with the info below?
1. Your app and drone's version info on About at General Settings;
2. The operations procedures before you saw "Gimbal not Install";
3. Is there any problem with controlling the gimbal with gimbal wheel;
4. Is the image transmission working;
5. Will this also appear except Active Track and Tapfly?
