Gimbal YAWS Automatically...
866 8 2017-8-30
randy.sauder
Flight distance : 872572 ft
Not sure what is going on with my Mavic...I've noticed that when it is hovering in flight OR just sitting on the ground that the video shows the camera slowly sliding/yawing.  Anyone experience this?  It is a very slow pan..VERY; I'd say it is close to 1/4 of a 'normal cinematic pan'.  It definately requires correction when filming; this requires you to reposition the Mavic which is not ideal.  Gimbal recalibrations don't make any improvment...
2017-8-30
gnirtS
Flight distance : 5712575 ft
Mine *might* be doing that too.  Im undecided if its yaw or the gimbal drifting.  Sometimes left, sometimes right.
As there seems to be a bug with the latest firmware meaning i cant extract a .dat file i cant look at the logs to see if it IS yaw or not to investigate.
Turning off the synchronous gimbal option in the menu might stop this if it is the gimbal.
2017-8-30
randy.sauder
gnirtS Posted at 2017-8-30 13:37
For me it is the gimbal drifting since it does the same thing when on the ground...
2017-8-30
LeafPeeper
Flight distance : 450075 ft
Agreed...there was supposed to be some fix in .1000 for the gimbal drift I think, but mine drifts more now when on the ground than it did with .900.   Not sure why at all....
LP
2017-8-30
DJI Thor
Flight distance : 13602 ft
Hi all, could you guys who encounter the problem with gimbal drift in the latest firmware please provide the video of this case to us? I'll help to check and forward to our engineers to check more. Thank you so much in advance.
2017-8-30
randy.sauder
LeafPeeper Posted at 2017-8-30 18:02
LP
I am on FW .800 an only just started having drift issue; many many flights on .800 without issues...then all of a sudden, drift all the time....
2017-8-30
randy.sauder
I will add also (didn't want to complicate things) that my Mavic IS ALSO NOT MOVING STRAIGHT. Exactly like the new thread on this same topic.  Never heard of either issues before and I suspect that they must be interrelated as both conditions happened exactly at the same time.
2017-8-31
fanseacc58a6
Flight distance : 694508 ft
Same issue here but on a p4p v2... I have the pvp2 pvp2+ p3p and all fly in a straight line. Mine yaws just like yours.
www.opspeculate.com
2019-2-23
randy.sauder
fanseacc58a6 Posted at 2-23 12:19
www.opspeculate.com
Wow..went to your website- great photos/vids!  I grew up in the Parry Sound area...any chance some of your media is from this neck of the woods (some of it looks familiar).  Great work.
2019-3-9
