New Osmo+ Firmware Released (31/08/2017)
107037 107037 2017-8-31
DJI Support
Flight distance : 2408 ft
China
Overview
• Firmware : v1.6.1.0
• DJI GO App iOS : v3.1.15
• DJI GO App Android : v3.1.11
What’s New?
• Added Lens Calibration to DJI GO to fix blurring issues that could occur when cameras were set to infinite focus.
• Fixed an issue where videos could not be opened when recorded under multiple light sources.
• Fixed an issue where some frames were overexposed when recording in 1080p 60 fps.
• Fixed an issue where the camera would zoom in when tapping to focus.
Notes:
• Calibrate the gimbal using auto-calibrate after upgrading firmware.
• If the firmware upgrade fails, restart Osmo+ and DJI GO app and retry.
2017-8-31
RcEaMan
Philippines
Should I update my osmo + with the new firmware eventhough I dont encounter any error with the fix of the new firmware update.
2017-8-31
Smaxta
Flight distance : 9944 ft
Ukraine
It looks like I would be first to report.
2017-8-31
Smaxta
Ukraine
Okay... DJI you done good with focus issue with this update. Well done
2017-8-31
Smaxta
Ukraine
After lens calibration Osmo+ becomes reliable with infinity focus so far. I'll continue to test it for now.
Still have an issues with limited record time for max 30 min and so on, but with reliable focus, Osmo+ becomes usefull tool.
2017-8-31
OmarBojorquez
Flight distance : 105997 ft
Mexico
Just updated my Osmo+ and DIDN'T NOTICE ANY CHANGE. My Infinity Focus is still not working, I don't know if there's anything I need to do on my device to apply this "Lens Calibration", as I don't see any option in the menu. I updated both the APP and the DEVICE.
Thanks in advance!
2017-8-31
OmarBojorquez
Mexico
  this is with Infinity Focus
2017-8-31
eColumbia01
The inifinity focus is fixed. Thanks DJI.
If folks cannot find the calibration setting, go ahead and delete the DJI Go app from your device and reinstall. I had this problem too.
2017-8-31
Smaxta
OmarBojorquez Posted at 2017-8-31 14:17
Thanks in advance!
Dear Omar, together with firmware have an pdf, describing how to do lens calibration and you need to calibrate, b4 U see result. If you have no calibration option in DJI Go app, I suggest you to reinstall application- just delete it and install again.
Hope it will help you.
2017-8-31
RcEaMan Posted at 2017-8-31 05:04
I would suggest to update to the latest version.
2017-8-31
Smaxta Posted at 2017-8-31 06:28
Well, 30 minutes limit cannot be changed, sorry for that.
2017-8-31
Thanks in advance!
Like Smaxta mentioned, there is a PDF about how to calibrate lens, please make sure the calibration is successful.
2017-8-31
RcEaMan
Philippines
Thanks DJI Mindy. I updated the firmware. When you say calibration is it gimbal calibration or lens calibration because I can only see gimbal calibration in my app. I already reinstall the DJI App. By the way where can I find the included pdf file?
2017-9-1
Smaxta
Ukraine
DJI Mindy Posted at 2017-8-31 22:55
May be sometimes... Together with active tracking ;) I'm optimistic
2017-9-1
Smaxta
Ukraine
RcEaMan Posted at 2017-9-1 03:09
An pdf included in zip file with firmware update. Lens calibration you'll find on main viewfinder screen, under mic control in camera settings on the right (or top, if you're using vertical orientation)
2017-9-1
AmaVideo
I tried updating my Osmo software  but the DJI assistant won't let me type in the box. its very frustrating
2017-9-1
AmaVideo
I tried updating my Osmo software  but the DJI assistant won't let me type in the box. its very confusing
2017-9-1
RcEaMan
Philippines
Smaxta Posted at 2017-9-1 05:36
Thanks again
2017-9-1
donachy78
Flight distance : 42228 ft
The firmware is totally unusable for me cause of unstability of the gimbal. The camera never stops to move, neither holding the trigger button to lock the gimbal. The gimbal always do minimal movement but noticeable in the video. Picture with long exposure (3-4 sec) are always unfocused cause of the movement!!! It's incredibile!!!!
I tried also with the osmo stable on the ground, it always move!!!
Maybe is just my problem but I did everything in the manual. Gimbal calibration, and camera calibration that is mandatory for this release.
2017-9-2
ShellPhoto
Me also gimbal is never still, will move tiny amounts with no input.. and this new firmware and app my Osmo+ is not working properly at all
2017-9-2
JaydenWong
I cant find the lens calibration in the app (i am using android phone) while I have checked that it is the newest version of the app already. could anyone provide help. My focus is not clear
2017-9-3
Tune345
Flight distance : 446138 ft
Ahhh ! FINALLY !!!  haven't tried it because i just found it out and it's 1.20 am ...i have been waiting for months for this update i was really hoping somehow DJI will email me about it. What did i miss ? or there is no feature like that available...i missed 4 days
2017-9-3
Asidhowz
Iran
The tiny movement of the gimbal has been a problem since the start, it's really poor that this problem remains, also connecting to the Osmo is really hit and miss, if your looking to wipe the Osmo out to capture footage, forget about it.. I have to spend an age just to connect, in the device screen it jumps between connected and disconnected and switches between the Osmo+ and the Inspire 1.. Im on Huawei p9 and a can confirm it has worked before the update
2017-9-4
Asidhowz
Iran
*wip the Osmo out
2017-9-4
Smaxta
AmaVideo Posted at 2017-9-1 08:18
Dear AmaVideo, an Osmo+ can't be conected to Assistant. You need to unzip downloaded firmware and copy it to the root directory on SD card. After that, just restart Osmo+ and wait until leds will stop blinking red-green with the some beeping at the end of update. After that you may check update completed successful on SD root dir txt file, delete firmware files and restart Osmo. Voila! You're updated ;)
2017-9-4
Smaxta
JaydenWong Posted at 2017-9-3 21:08
Jayden, cheers. I wrote few day ago in this tread how to perform lens calibration- on main viewfinder screen, in camera menu, under mic control (need to scroll down). Procedure are well described in the pdf, included inside zip file with firmware upgrade. In case you have no lens calibration option in DJI Go app, people suggest to delete app from your phone and reinstall it again. Hope it will be helpful to you.
2017-9-4
Slendermouse
Flight distance : 37444 ft
I have also just done the update and now have gimbal movement when there should be none.
Its hard to tell when your moving around with the Osmo+ but as soon as you try to use a tripod it makes the footage unusable.
It looks like you're on a ship, rocking backwards and forwards in a tiny circle.
Is there any way to stop this movement?
Thanks
2017-9-4
donachy78
donachy78 Posted at 2017-9-2 02:42
Some answer from DJI Official about this problem???? It seems that is not only a problem of mine!
Before this update my Osmo was totally stable and I took a lot of picture with long exposure just holding it in my hand without any movement!!!
2017-9-5
Please refer to Smaxta's suggestion on 25#, please keep us updated if you find the lens calibration, thanks.
2017-9-6
Do you mean the firmware of Osmo Mobile? Osmo and Osmo+ cannot be updated by DJI Assistant 2.
2017-9-6
Could you please upload a short video about lens drifting? We need it for analysis, thanks.
2017-9-6
ShellPhoto Posted at 2017-9-2 07:49
2017-9-6
Asidhowz
Here is a quick vid, I reset everything, reflashed the new firmware and the micro gimbal movement is still there.. impossible to take stills with this movement especially long exposures
2017-9-6
iC5G60wW6hBq
Croatia
I installed new osmo + software and made the lens calibration, the picture is a bit better but the distance is still blurry. Should a calibration be made in photo or video mode?
2017-9-6
CanonMax
Flight distance : 8953215 ft
Asidhowz Posted at 2017-9-6 11:14
Waar o waar is this video?
2017-9-6
Asidhowz
Believe it or not after spending half an hour trying to connect to the Osmo as the app thinks it's the Inspire 1 I i finally recorded a static video of a book and the micro movement is clear, closed the app but forgot to download the high res version so here is the low res taken from my phone, the movement is quite clear, now again I'm cannot connect to the Osmo+ it's in a connecting/disconnecting cycle, WiFi is connected, the app will not... Sick if it really.. this thing is an absolute pain to use, my MAVIC is a joy..
https://youtu.be/45hf6azZUfk
2017-9-6
Asidhowz
Travelling around Iran and this Osmo+ being is wasted, joke shop
2017-9-6
Asidhowz
Reset everything, reflashed firmware, forced stopped everything and again, nothing
2017-9-6
iC5G60wW6hBq
Croatia
How to make osmo + lens calibration in photo or movie mode? In photo mode the frame is bigger in movie mode, is it normal? the infinite focus is still bad.
2017-9-6
iC5G60wW6hBq Posted at 2017-9-6 12:00
Please check the guide of lens calibration: https://www.dropbox.com/s/pyty5t ... on%20Guide.pdf?dl=0
2017-9-6
