randy.sauder
Flight distance : 872572 ft
MDJ Posted at 2017-8-31 23:52
I read the graph as showing that the new props model are 10dB lower than the old model/props - not the other way around. That spike seems to show that the existing Mavic Pro with existing props has the spike at 70Hz but that the new model/props does not have the spike.
What isn't clear and, you're absolutely right, needs to be tested in real world conditions is the extent to which the new props are the sole contributor to this and how much is related to the ESC's on the new model. I'm hoping that, when it comes to noise, the props are the main contributor and that the ESC's on the new model contribute mainly to the slightly longer flight time.
Look at the SECOND hump on the graph; 700Hz...new props are +10 dB higher than old ones (you are correct at the FIRST hump on the graph). Concerning also is that this corresponds with the normal hover RPM of the Mavic. This new bent prop-tip is quite common in advanced heli designs (although I doubt the Mavic's props are supersonic as helis are ). A theoretical improvement for sure but we'd have to experience it to judge if it is actually noticeable. I agree with you about the noise of the motors vs the props being the main factor in noise performance- for UAVs I'm sure this is the next step in innovation (if they can fix/lower this noise). Another big concern for me with these new props is how they may fair in crashes/prop impacts to objects etc. I've found the current props are very good at resisting damage. The new design puts notches in the exact locations where prop impacts ocurr- and I suspect that this will create a susceptibility for the props to more easily be cracked at these locations due to the notch-effect/weakening of the prop tips.....I hope not. Eager to try them out and rule out marketing hype! |
