DJI Thor
Flight distance : 13602 ft
fans494a97df Posted at 2017-9-2 12:10
Hi Susan,
After the firmware update, I constantly have to calibrate after each new battery and each new time out. The AC does not hover in place. It moves around without any wind. When I fly slowly, it speeds up and goes off course. Any adjustments in slow flight, is incredibly touchy. just a bump of the controller and the AC acts like I held it down and the adjustment is to much and the AC speeds up. With no wind, I get the "high wind" warning. I get loss of signal between AC and RC and I lose video during flight. When in flight and stopping, the AC goes off course and doesn't stop in the distance it used to. I am not an expert video person, but in auto the camera is not adjusting to the light as before causing any video in natural light adjustment to be useless. I have never used any filters.
For your case, I recommend that you first confirm if the upgrade completed, version info with +/- symbol means the incomplete upgrading, you can check in this route: connect the drone, RC, and the app---enter device---general settings---about. You can also refresh the firmware again. Then please calibrate the IMU and compass. For the strong wind warning, please note that the wind speed mentioned above is not the wind speed on the ground, but the one in the air. Besides, if you lose signal in a short distance, please try to adjust the position of the antennas. If the problems still persist, please contact our support support.us@dji.com for a further help. Thank you. |
