RicardoGray
Flight distance : 4356421 ft
PWingers Posted at 2017-9-21 07:59
I'm fairly certain that I haven't loaded the wrong software. I tried reloading the software but it doesn't want to know now and just bleeps one short then one long over and over. I left it running like this for 45 minutes before turning it off.
Very disappointed with it. I wish I hadn't loaded the new software in the first place because it was fine before.
I would suggest you try to give it time to try and finish. You are not doing yourself any favors by shutting it off. A corrupted install only causes more issues. I can only share with you that I had a similar experience helping a friend of mine. Can't tell you now what version it was or any real specifics, but here is the quick story. He had trouble trying to upgrade on his own, and after several attempts he brought it to me. I ended up downloading the correct firmware at that time, and started off fresh if you will. Formated sd-card, etc. Upon upgrading the aircraft, I turned it on and it made some very strange noises and lights were going crazy. After a short time and tired of listening to it, I took the aircraft and put it in my basement and left it there. After an hour I checked on it, and still strange things going on but I didn't touch it.....let it continue. No kidding, after 1 1/2 hours I checked on it again, and holy crap........all was perfect. making the D-DD sounds , light were good etc. No noises or anything. It has been flying perfect ever since. Now, I can't say I have the answer to your issues, but I did learn something myself on that one. I have never had anything like that on my own P3A, but I can tell you that is what actually happened with my friends. I just think maybe your installation is somehow corrupt. You have nothing to lose the way I see it. Charge up your battery, try it again, and leave it on. I hope you can get it figured out. |
