Matioupi
Flight distance : 922569 ft
Currently, the gimbal wheel is "horizontal" while it commands an up and down movement.
I believe that in terms of ergonomy, things would be better another way.
My opinion is that a "balance type" 2 positions button solution on the left side of RC(replacing the wheel) would be better.
- the gesture is simpler
- they could be vertically aligned so that the direction of command is more natural (a vertical wheel would make the gesture a bit hard I believe)
- it could be possible to have a "tilt while you press" mode and a fix tilt step (e.g. 5°) per short press mode
What do you think ?
