ImHereToCrash
Flight distance : 5381368 ft
they are some form of a poly type of plastic.. meaning mixture.. probably a nylon based mixture makes the most sense, since nylon is incredibly strong and flexible (basis for making kevlar is nylon) .
but also can get brittle with improper treatment.. downside of nylon they dont like temperature swings, so hot to cold cold to hot will age them quicker, UV (sun light) will brittle them up rapidly as well. but is probably the least evil option given other poly/plastics fail with less stress or warp or fail catastrophically..
i had bad luck with 2 blade so far.. both have cracked completely on their own (as far as i can work out).. since swapped to a fresh set of blades all 4 corners after finally receiving replacements from amazon and they work a real treat so far.. it may take days for a stress crack to appear for me though so if it happens without my crashing ill be complaining.. |
