Yoan
Flight distance : 93806 ft
Hello DJI Thor,
thank you for your response.
Regarding a possible indoor mode, here is my idea. As a GNSS engineer, I know that the availability and the accuracy of a position from a GNSS receiver is affected when it is indoor (more or less, depending if it is light indoor or deep indoor environment). Then, I assume that when flying the Mavic indoor (or in any difficult environment with masking), the navigation system of the Mavic may sometimes get a GNSS position, sometimes not. And then the Mavic would probably switch between ATTI mode and P-mode in an unpredictable way. This can be difficult to manage for the pilot. Not taking into account the GNSS position, even if available, would probably make the Mavic drift more, but its flight may be more predictable which is important when flying indoor or in a canyon, for example. As I don't know exactly how the Mavic works, maybe what I am trying to describe is simply the ATTI mode, but I am not sure.
Regarding Mavic settings, I experienced at least twice a change in the configuration without any firmware update. The last I remember with a change in the picture configuration, it changed from RAW+JPEG to JPEG only (I did nothing special, just change the battery between two flights). If all the settings are stored in the Mavic memory, then it would be interesting to download them to the smartphone. It would then allow to restore them all at once, and more interesting, allow users to share there best settings with the community.
Thank you again for taking my ideas into considerations.
Yoan |
