899 15 2017-9-2
Ethan-brown19
Flight distance : 81745 ft
Turn off obstacle avoidance the you will go faster!
2017-9-2
fans665a76ad
Flight distance : 20 ft
Won't go faster than 5mph unless in Spirt mode
Not in beginner mode or Tripod mode. I've tried an Imu calibration but it won't go past 95% completed
Any ideas anyone
2017-9-2
fans665a76ad
Won't go faster than 5mph unless in Sport mode
Any ideas anyone
2017-9-2
fans665a76ad
I'm sure it's the imu that's causing the problem, but I can't complete the calibration
2017-9-2
fans01923024
Flight distance : 22651 ft
It worked for me same until I changed stick response sensitivity to high. Maybe that's same in your case.
2017-9-2
Sparky_17
Flight distance : 62349 ft
Yes, change the stick response and that should fix it
2017-9-2
S-e-ven
Flight distance : 5922034 ft
Thailand
Yep, check obstacle avoidance and stick response.
If I remember right, the update did reset the one to "on" and the other one to 50% or such.
2017-9-2
JackChoi
Flight distance : 16284928 ft
South Korea
i have same problem. Mine is 9 km/h in P mode.
2017-9-2
SeanGillian
Turn off "Obstacle Avoidance" will go a little faster, but not as fast as in SPORT mode....
2017-9-2
S-e-ven
Thailand
Also check on the settings for the joysticks to get the last kph / mph even with obstacle avoidance on
2017-9-2
Madwand
Flight distance : 73018 ft
Isn't that how fast it's supposed to go when not in sport mode?
2017-9-2
S-e-ven
Thailand
Afaik:
~11 km/h (w o/a)
~22 km/h (w/o o/a)
~50 km/h (w sp)
And less if joystick controll is not full sensive
2017-9-2
fans665a76ad
And how do you change the stick response?
And also any idea why I can't calibrate the I'm? Sticks at 2 seconds remaining every time
2017-9-3
HomePoint
Flight distance : 776007 ft
Spark flies at no more than 6mph with obstacle avoidance on.
Spark flies at around 13mph with obstacle avoidance off.
Spark flies at around 30mph with Sport mode enabled.
2017-9-3
fans61699a75
Flight distance : 24897940 ft
I also noticed spark is flying much slower with this new update.
It could be possible that it has got to do with saving battery juice , as update was also concerning batteries.
Dji ? Please give feedback? If this is the case?
2017-9-3
DJI Thor
Flight distance : 13602 ft
Please refer to the IMU calibration tutorial below. The new firmware doesn't decrease the speed of flight, and the theoretical max speed is 6.7 mph in P mode when forward obstacle sensing is enabled. But if there is the wind, it might affect the speed. Please check your gain settings in MC Settings, you can also calibrate the RC.
2017-9-3
