Fruxen
![](https://forum44.djicdn.com/data/attachment/common/c5/common_13_usergroup_icon.png) lvl.4
Flight distance : 1370630 ft
Sweden
Mabou2 Posted at 2017-9-4 08:11
I realize that on a surface level, it doesn't make sense that the SD card could affect the stability of the bird (as many have pointed out here). But you are looking at the problem too simply. A great example of how this can happen involves a quick history lesson with computers. I don't know if this still applies, but it used to be when you were doing a software upgrade, Apple required us to disconnect all external hard drives and ALL third party peripherals because their presence could adversely affect the quality and accuracy of the software update on your main drive. It didn't really make sense that having an external hard drive connected should affect the quality of the internal hard drive update, but it was apparently enough of an issue that the documentation required disconnections of all peripherals.
The same kind of thing could be applying here. By having an SD card in the slot, something goes wrong with the firmware installation, which causes the issues we are having. A bottom line is, many of us have problems after installation, but most likely many more had no problems. The granularity of the problem could even go into silly space. For example, the update works fine if you have formatted the card recently.... or the upgrade might be fine if you have nothing recorded to your card. I know these are probably extreme examples, but that is exactly the way odd bugs are introduced.
On Windows there is a procedure like this where you in some cases should remove secondary hard drives before a fresh install. But that has nothing to do with system stability, just that the proper drive is selected as the boot drive when the computer starts. But nothing boots from the SD card in a Phantom, and the SD card cannot possibly affect flight performance.
I understand that people are trying to be helpful, but this superstition about the SD card is only confusing. Not trying to sound harsh but some advice is on the level of
"Yesterday my Phantom flew unstable. But today, I had a cheese sandwich before flying, and it was much more stable! Everyone should try eating a cheese sandwich. At least it can't hurt." |
