Dick Heiser
Flight distance : 57543 ft
DJI Thor Posted at 2017-9-3 01:46
Please refer to the answer at 2#, check if you are in NFZ. Besides, did you get any messages when you got the limitation? What was that? Please try to restart the app or log in your account again. You need to connect the drone when you change the drone's settings or it is not stored. For the NFZ database updating, if you can not update it via the app, please try to update it by DJI Assistant 2.
Thank you. When the drone is connected, I can't change the max distance (328 ft) or max altitude (164 ft). But I can't get even this distance. It's been stopping at 146 ft distance; once I used a "circle" intelligent mode and followed a boat past the maximum distance. I'm flyingin a warning zone, but not a no-fly zone.
Somebody else is having trouble updating the NFZ database, too. I'm trying to do the update at home, which is in a NFZ, where I cannot take off. I've been trying with DJI Assistant. Can't find how to update with DJI Go 4. Just now found the DJI Go 4 update on the App Store. I'm not able to check the version of the installed DJI Go 4 app, but am updating to 4.1.9. How can I update the NFZ database with the DJI Go 4 app? |
