Mark Guille
Flight distance : 2031818 ft
Jersey
It can be very deceiving when flying at that sort of distance, you think you have easily gone far enough when you are actually only little more than half way. As for manoeuvring around tight space, you are playing a dangerous game when in VLOS, forget about attempting this in FPV at that sort of range. Even if you have the highest resolution available, a fraction of a second of lag could spell the demise of your drone.
You can adjust the transmission quality in your setting but I strongly believe this is not your problem here. Find out where this bouy is and how far away it is from your take-off point (using Admiralty charts or similar) and navigate your way there, you will find it.
If you're hoping to get your bird back after the mission, never fly out with the wind behind you, it will be against you on the way back!
Good luck and (try to) fly safe.
Mark G. |
