Maximum Amps draw during flight for P3 Advanced
Cessna172
ANyone know what the MAXIMUM draw, in Amps the battery will need to deliver on a P3 Advanced during flight ops?
2017-9-2
DJI Susan
Could you be more specific of your main problem?
2017-9-4
solentlife
Flight distance : 1087530 ft
Latvia
Its easy to work out ...
Charge up .... fire up gear...
You can then take off and fly repeated lines at full throttle ....
Take the total capacity .... minus the remaining after flight .... take the flight time ....
Simple maths will give you the averaged draw ...
I would then say that the figure obtained is probably about 90% of max draw ... why ? To be safe in number and not have a low figure.
Unfortunately DJI's design prevents us from using Wattmeter as we would do with other RC models ... giving direct readout of Watts / Amps etc.
Nigel
2017-9-4
