sibu
Flight distance : 322454 ft
Kuwait
fans57703823 Posted at 2017-9-16 21:57
HI, sibu,
I have the same problems as you. May I have your advice how to reinstall the software for RC by DJI assistant 2 ??? I connect the RC with my PC, but there is nil response from DJI assistant 2.
Hi There,
The RC can be updated using the wifi . The SPARK needs to be connected to the DJI Assistant 2 for firmware update. You need to update the RC and SPARK firmware once you have two batteries or so. For some reason the software gets corrupted or doesn't install in the first instance correctly or the order of firmware update is not right as described by DJI.
But the trick works perfectly once you reinstall the software on both equipment and get a confirmation screen that the firmware is updated. Then follow the instructions regarding basic controller movements of the SPARK which I have mentioned earlier including IMU and compass calibration.
I had all sorts of problems including
a) drifting ,
b)SPARK falling from the Sky ,
c)over load gimbal motor ( obviously due to the fall ) ,
d) left ESC motor overload,
e) SPARK moving like a wave , ( UP/Down motion) ,
f) SPARK not rising above 6 meters high even with GPS locked ...
All the above symptoms were scrutinized in detail and fault cleared completely.
These symptoms were due to various errors from my side as an operator including
i) improper propeller guard mounting,
ii) bend/chipped propeller blades,
iii)cracked rear wing,
iv) Updated to latest software after receiving threat from DJI but updates were not set properly in the SPARK or not happening due to two batteries firmware update requirement
These can be solved from our side if we have an interest and patience . DJI is a good product as far as my experience goes. Even with all these problems, I see the SPARK as a very robust quadcopter.
