This is 2nd test and using ARGtek Dual Band Omnidirectional 8dBi antenna and also connect the OTG cable to fly without using WiFi signal.
So by using OTG connection the live view is smoother than using WIFi signal, as you can see the AZ Screen Recorder capture the live view is very smooth.
This 2nd test the range is much further than previous the 1st test, the 1st test range i getting 2,745m and this 2nd test manage to get 2,821m, maybe because this location have less interference. So remember different location will have different weather/environment/WiFi interference.
Overview
- Aircraft Firmware: V 01.00.0600
- Remote Controller Firmware: V 01.00.0400
- DJI GO 4 App iOS: V 4.1.7
- DJI GO 4 App Android: V 4.1.5.3
Nelsonlee, increasing signal with the enhancer can be effective. However, we would not recommend this kind of operation as it is dangerous and out of warranty. Thanks for understanding.
