need a downgrade on p3p, please help
1450 25 2017-9-3
Adepto
hello everyone. since i've been waiting for answers by dji admins, dji assistence on the reason why my p3p is not working at all but didn't get any answer, i kindly ask everyone to help me downgrading my p3p to the last stable firmware and sotware version.
please could someone write the app version, rc version and drone firmware version the get my phantom work again?
thank you in advance.
2017-9-3
Cetacean
Flight distance : 2494390 ft
Aloha Adepto,
     Here is a link to all the information you need for stable firmware and app versions.
https://dl.djicdn.com/downloads/ ... +Release+Notes_.pdf
     Then once you choose what you want, go to PhantomHelp.com and look in the Software or firmware directories.
     Hope this helps!
Aloha and Drone On!
2017-9-3
DJI Susan
I have checked your previous posts and I do not think it is related the firmware directly. I would recommend you to connect the aircraft and RC directly(without app) to check whether it works.
BTW, please reply us directly by clicking the button under my reply so that we can handle it timely. Thank you.
2017-9-4
Adepto
Cetacean Posted at 2017-9-3 17:58
Aloha Adepto,
thank you, i will give a look on it for sure as soon as i will have some time
2017-9-4
Adepto
DJI Susan Posted at 2017-9-4 02:18
sorry susan, i didn't know the "reply" function.
how can i get connection between rc and drone without passing through the app exactly?
2017-9-4
AerialSpotlight
Flight distance : 9721 ft
So I just update my firmware and the P3P app as recommended and now I can no longer connect to my drone. I fly yesterday perfectly and now with the "upgrade" I"m completely grounded. Is this the same issue you are having? HELP DJI!!!
2017-9-4
MrBubble
Philippines
Hello, i have an issue about.the limitation 30m height and 50m radius with my p3 advanced, and ipad mini.2 after last firmware updates. i read that if i am logged in the Go ap then the limitations dissapear...yes dissapear, but as soon as i.change the battery to fly again then appear this restrictions again.....i can log out and log in again, but not always i have internet to do it, i tried to uninstall and install the app and still giving me same issue...Any.ideas?
2017-9-5
Adepto
AerialSpotlight Posted at 2017-9-4 15:38
yes the same
2017-9-5
Adepto
MrBubble Posted at 2017-9-5 03:42
no idea, i can't eve start flying
2017-9-5
DJI Susan
Adepto Posted at 2017-9-4 13:32
It's ok. Please refer below and have a try:
a. Turn on both the aircraft and the controller. Hold C1, C2, and the record button (top left button) on the controller.
b. Then press the wheel on the right side of the controller
c. Use a tool to click the linking button on the aircraft and hold for 2 seconds, and then take the tool off, it will link soon.
2017-9-6
DJI Susan
Both the aircraft and controller have been updated to the latest version, right? Please try to link RC:
2017-9-6
DJI Susan
Please make sure both the aircraft and APP have been restarted when you changed the battery.
2017-9-6
SkyCamera
I have the same issue.
tried many tricks, none is working.
Have to wait for DJI to release new firmware to fix this. please!!!
2017-9-6
Adepto
DJI Susan Posted at 2017-9-6 01:47
susan i've tried this many times, it doesn't work
the linking procedure succeeds but then i cannot fly
2017-9-7
DJI Susan
Adepto Posted at 2017-9-7 04:49
How about starting the motors without APP? Post a short video for better assistance, thanks!
2017-9-9
Adepto
DJI Susan Posted at 2017-9-9 01:57
Motors do not start, but i can move the camera.
here is the video
2017-9-10
DJI Susan
Adepto Posted at 2017-9-10 08:25
here is the video https://vimeo.com/233193342
Well received, thank you! It looks like the hardware issue, please contact the support and send it in for diagnosis: http://www.dji.com/support.
2017-9-11
Adepto
DJI Susan Posted at 2017-9-11 00:40
there is no way to fix this by myself?
2017-9-11
DJI Susan
Adepto Posted at 2017-9-11 01:57
Sorry, we do not support to take apart the drone or repair by your end. Our engineers will do flight test so that you a get a working drone.
2017-9-11
mrbill
Flight distance : 717100 ft
I've upgraded rc and drone to the latest p3p firmware, and it flies fine, but now has a horribly laggy video feed.
Anyone else got any thoughts?
2017-9-23
wntmldrs_belgiu
Flight distance : 793281 ft
Belgium
I was lucky three weeks ago. My P3P was repaired by DJI and came back with the old firmware !!! Made me very happy.......
2017-9-23
Mark The Droner
Flight distance : 2917 ft
I would research before you downgrade your AC FW.
Here's a thread I stumbled on this morning and it is pretty terrifying:
https://phantompilots.com/thread ... -9-to-1-7-6.105384/
2017-9-23
mrbill
wntmldrs_belgiu Posted at 2017-9-23 13:29
What firmware version is that?
2017-9-24
wntmldrs_belgiu
Belgium
mrbill Posted at 2017-9-24 00:59
firmware 1.10.90
2017-10-18
GuitarFlyer47
Flight distance : 38747 ft
DJI Susan Posted at 2017-9-6 01:53
Susan, I wrote you about this on another post, I found I have to shut my IPhone off, then back on, then restart the RC,  and P3 Pro.   This is the only way I can get past the fight height limitation.  I also called your support team and spoke with someone in China, he said they know that the new IOS update and the GO app are having compatibility issues.
2017-10-19
DJI Susan
GuitarFlyer47 Posted at 2017-10-19 19:21
Sorry for the late response first. It seems that you have got rid of the restriction now in this post: https://forum.dji.com/thread-116383-1-1.html  If you have any further questions, feel free to contact us.
2017-10-24
