Gimbal error - rocks back and forth
TGoedde
Well this is fun. Now my gimbal just rocks back and forth and doesn't stop no matter what resetting I try. Says
'"Hardware mailfunction, contact dji for repairs" Fun! I've flown it 5 times!
2017-9-3
ActionJaxon
Get your money back if its not too late and if you get a new one DONT UPDATE THE D*MN FIRMWARE no matter what you do!
2017-9-4
DJI Susan
Have the drone been crashed or not? Post the error message and I'll check.
2017-9-4
TGoedde
DJI Susan Posted at 2017-9-4 00:28
No crash, no issues. Worked great one day, not the next. I did not do the firmware update.
2017-9-4
ALABAMA
Flight distance : 10442687 ft
Sounds like a rock solid case for refund or replace.   How long since purchased?
Good luck!
2017-9-4
TGoedde
Got it last Wednesday!
2017-9-4
DJI Susan
TGoedde Posted at 2017-9-4 06:37
Please contact the Support and send it in for diagnosis: http://www.dji.com/support.
2017-9-5
TGoedde
ALABAMA Posted at 2017-9-4 06:53
Good luck!
Returned it, got my new one today and am playing around with it now.
2017-9-7
ALABAMA
TGoedde Posted at 2017-9-7 15:48
Good deal!  Better luck with this one
2017-9-7
Shockdoc1
Iceland
Hi guys,
I just had the same issue with a Mavic Pro. Gimbal went back and forth. Calibrating of IMU didn't help, calibration of gimbal was only possible to 5% then aborted after some minutes. I read a lot about replacing the ribbon cable or gimbal arm or starting the drone upside down or slighty turned to the right. Nothing helped.
For me the following procedure fixed it:
- start drone with clamp for gimbal attached (!)
- start calibration of gimbal (clamp attached)
- after calibration startet (showing 5%) I removed the clamp
Calibration went through up to 100% then everything was fine again.
2020-7-26
