Color shift while filming
1108 10 2017-9-4
MaikR
Flight distance : 322087 ft
Hello,
I have some rare color shifting going on while filming. Look at the clip posted around 0:33 seconds. Had this a few times now.
Somebody knows why the color shifts like that?All camera settings where on manual.
thnx.
2017-9-4
Juanmi
Flight distance : 19948 ft
Try to lock the White Balance in one mode and not in Auto...
2017-9-4
Montfrooij
Flight distance : 2560453 ft
Did OP not say everything was manual?
2017-9-4
Montfrooij
Did you have it in good lighting also?
2017-9-4
DJI Diana
Flight distance : 2408 ft
Do you have this issue while filming a video in a well-lit place? If yes, please upload an original video from the SD card to the Dropbox, so I can download it for analysis.
2017-9-4
MaikR
Juanmi Posted at 2017-9-4 11:53
It was indeed locked. It was getting dark and haven't seen in it in daylight footage before.
@DJI Diana, will try in other place to reproduce.
thnx all.
2017-9-4
Montfrooij
MaikR Posted at 2017-9-4 23:12
I can imagine the darkness plays tricks on the auto white balance, but when locked it should not be a problem.
2017-9-5
jksphoto
Flight distance : 114121 ft
Sweden
Just wondering if that the exposure compensation adjusting. I can't understand why this cannot be changed in manual mode.
2017-9-5
MaikR
jksphoto Posted at 2017-9-5 03:00
exposure was set at 1/40 and iso at 200.... if you set it manual there is no need to compensate ....
2017-9-5
jksphoto
Sweden
MaikR Posted at 2017-9-5 03:05
Very true, but if you notice, the exposure comp cannot be adjusted when the camera is in manual mode. The Spark changes this.
If this was on a DSLR, the whole process of manual, is so you set the settings you want.
2017-9-5
Montfrooij
That is true for manual mode, although I can set compensation on my DSLR, making the light meter react different.
I guess Spark does not have that.
2017-9-5
