DJI Thor
Flight distance : 13602 ft
Hi there, for the Map Loading issue, there may have two scenarios that lead to this error.
1. If the GPS signal is weak at the starting point of the flight trace, the flight record will show map loading.
2. If the GPS signal is normal and the flight record still shows map loading, it is normal. If there are too many accesses in a day, the request for the location may not be answered normally, as a result, the location cannot be displayed and the flight record is displayed as map loading. After a period of time, the flight record will return to normal and the corresponding position will be displayed correctly.
For the No GPS display, No GPS occurs when GPS is weak at the starting point of the flight trace.
Hope this provides you with some info. |
