Dronoob
Flight distance : 126079 ft
I can imagine that the following happened at the hotel: The drone got disconnected (for whatever reason) and was configured to hover in place. That is what it did. At some point it noticed that the battery was low and returned to home. If you started very close to the roof of the hotel, this could be an explanation. Not knowing the configuration of your Mavic, this can be totally wrong.
The next day, the drone got disconnected again. With the configuration above, it would have hovered in place for some time before it decided to go back. If the way back was against the wind, it did not get back before it went out of battery. So, the drone might have stopped the flight back and started to land. If that is what happened, you might find your drone in a direct line between your home point (where you started) and the point where the disconnect happened.
Some hints for the future:
1) Maintain a VLOS - visual line of sight.
2) Put your contact details on the drone.
3) Set all emergency option properly before you fly (set proper home point, behaviour return to home or hover in place, safety height, ...) |
