Mavic RC damaging USB cable
1071 11 2017-9-5
Jinjur
Hi all,
Only getting back into flying after Mavis was returned from repair.
However, I have noticed that the remote is cutting into my little reverse style usb connector where it recesses into the side of the remote. I have a pic but can't put it up yet as I am in work but just wanted to sound out if anyone else is seeing the same?
These little cables are super thin and soft and I dont think it is going to last long at this rate.
The recess on the side of the remote is very sharp too.
Just me or not?
J
2017-9-5
DocAraxá
Flight distance : 202283 ft
Brazil
I will see, carefully, mine.
I didn't notice anything at all, but I will be cautious.
Thanks for sharing your situation.
2017-9-5
Jinjur
Hey guys.....see below
Anyone else seeing this?
2017-9-5
AG0N-Gary
Flight distance : 700846 ft
I've never seen anyone stuff the wire into the slot before.
2017-9-5
Jinjur
Pretty sure that's what it is for bud :/
2017-9-5
DJI Susan
Could you tell me your case number?
2017-9-5
Jinjur
Hi Susan,
I haven't raised a case as it hasn't actually failed. I guess I am just a bit concerned that it will
Dont know if i am being daft or not?
J
2017-9-6
DJI Susan
Jinjur Posted at 2017-9-6 00:54
Hi Susan,
Is it the Android cable or IOS cable? I will check and forward the designated team try to resend a cable for you. Thanks!
2017-9-6
Jinjur
Hi Susan,
It is the Android cable. Do you have any thoughts on why this is happening?
Obviously, some users think i should not have the cable tucked in? Perhaps its my fault then? If it is my fault you definitely don't need to send a cable, wouldn't be fair.
But if this is an issue, should i try and remove the sharpness from the edge of the recess of the remote or something?
Thanks for your help
Andy
2017-9-6
Jinjur
Hi Susan,
Ok. I softened the edges of the remote recess, I hope it will help.
It just looks like some roughness left by the casting process. It has definitely cut the cable though.
Would you be able to send a replacement or do i need to raise a case for this?
Regards
Andy
2017-9-7
DJI Susan
Jinjur Posted at 2017-9-7 08:53
Hi Susan,
Andy, I have forwarded it to the designated team for further assistance. And they will arrange for you soon.
2017-9-7
DJI Susan
Hi Susan,
I have PMed you the UPS tracking number, please check and confirm. Hopefully you will receive it soon.
2017-9-7
