Full throttle descent question
2444 25 2015-4-2
drklion
Flight distance : 2712825 ft
For those that may have done a full throttle descent (just using left stick fully pressed down) without knowing that it would put the bird into a VRS did you notice the bird stable or did it rock back and forth?
Thanks
2015-4-2
DJeff1
I would not attempt a full throttle descent because of the possibility of the introduction of a vortex ring state.
2015-4-2
Ph02on
Flight distance : 75673 ft
This is known as Vortex Ring State.  Full throttle decents should be avoided at all cost. This video will explain better than I can.
Cheers
Jason
2015-4-2
drklion
I understand the vortex ring state.  I am concerned on the stability.  On the Inspire 1 it seems to stabilize this descent to avoid the VRS if in full throttle descent.  I AM NOT ASKING ANYONE TO TRY IT.  Please let me know if you can recall stability or the rock and roll motion from experience.
Thank you.
2015-4-2
DJeff1
I have not experienced because I do not do full throttle descents.
2015-4-2
w1der
Sweden
If you push the right stick slightly "forward" (or any direction) at the same time as you push the left stick down to the maximum, you will get a stable flight downwards ...
If you don't do this it starts "rocking" ... YES!
2015-4-2
kgarrison
Flight distance : 11736709 ft
Yes, it will wobble while it tries to maintain stability. This is why it is a very very bad idea to do a full throttle descent.
2015-4-2
Dangair
If you pull the left stick all the way down and hold it there for a few seconds you may land a tad faster than expected!
2015-4-2
markjacobs.talk
Flight distance : 120784 ft
Dangair Posted at 2015-4-3 01:46
If you pull the left stick all the way down and hold it there for a few seconds you may land a tad f ...
If you push the right stick into the bottom right and push the left stick to the bottom left at the same time you land even quicker!
2015-4-2
wolftj
Flight distance : 109734 ft
drklion - Read up on VRS and you will be able to answer your own question, I believe.
2015-4-2
drklion
wolftj@mindspri Posted at 2015-4-3 03:37
Yes, I understand VRS as mentioned above.  I am looking for some who may have done the full throttle descent without realizing it is a bad idea and may have noticed that it was stable or wobbled because of the VRS.
Thanks
2015-4-2
jhogge
"If you push the right stick slightly "forward" (or any direction) at the same time as you push the left stick down to the maximum, you will get a stable flight downwards ...
If you don't do this it starts "rocking" ... YES! "
Exactly as this poster stated. When I need to descend quickly I fly in wide circles to maintain forward movement and it is perfectly stable.
If no forward movement it will start rocking enough to scare the crap out of me.
2015-4-2
drklion
jhogge Posted at 2015-4-3 06:29
"If you push the right stick slightly "forward" (or any direction) at the same time as you push the  ...
Thank you for the reply.
2015-4-2
doctrrf
I've used full left stick down with my Inspire 1 many times with no problems.
Most of the death wobbles are caused in part by low batteries: typically VRS occurs late in the flight, the battery is low, and the motors simply don't have enough punch to correct the wobble unless you correct and get some lateral movement going to bring in clean air.
Here's my Phantom 2 playing around with VRS:
2015-4-2
dlew21
Flight distance : 3963865 ft
drklion Posted at 2015-4-3 00:26
I understand the vortex ring state.  I am concerned on the stability.  On the Inspire 1 it seems to  ...
Should be normal
2015-4-2
dlew21
doctrrf Posted at 2015-4-3 09:05
Most of the death wobb ...
I've never had a wobble on full throttle descent..  I think it is a battery issue
2015-4-2
rickc309
I do full throttle decents now and then. The I1 handles it perfectly. My P2 also has no issue at all with it.
2015-4-2
drklion
Thank you all for the reply.  Now it is starting to be clear.  The battery may be at fault if not fully charged or at least have enough juice to counter act the VRS.  Again thank you all for your input.
If I get some info from DJI I will post.
2015-4-2
Dangair
markjacobs.talk Posted at 2015-4-3 01:53
If you push the right stick into the bottom right and push the left stick to the bottom left at the ...
No it will take same amount of time as pulling the left stick to the bottom and holding it there will kill all motors too.
2015-4-2
doctrrf
Dangair Posted at 2015-4-3 12:35
No it will take same amount of time as pulling the left stick to the bottom and holding it there w ...
The left stick, by itself, held down will kill the motors only after landing, same as the Phantom 2. In fact, the latest Phantom controller comes with a clamp on the left stick to hold it down during descent.
2015-4-2
Dangair
Have you tested this? Because I pulled the left stick down on the sim and she landed rather quickly!  The fear I have is that it will behave oddly like so many other glitches that have surfaced and I will have a lawn dart!
2015-4-3
ssteenberg
I use full throttle all the time to bring it down.
2015-4-3
markjacobs.talk
No it wont.
Left stick to the bottom will be minimum throttle but will not cut off the motors as long as the internal barometer is receiving changing barometric pressure data.
CSC command will kill the motors IMMEDIATELY irrespective of any other sensor or flight controller condition.
So you are incorrect since minimum throttle will maintain flight, but CSC will initiate free fall and the Inspire will achieve terminal velocity.
2015-4-3
drklion
So far you have been correct.  All indications fall on the battery power.  No problem today with full throttle descent and battery fully charged (90%).
It does not mean it is safe to do.   I am not condoning this maneuver.
2015-4-3
Dangair
Good! I'm glad I'm incorrect. I was seriously concerned about that and was thinking of hang testing it. But if you guys are saying that you have confirmed that the throttle alone won't kill it in flight, that answers my question. I find sometimes that the best way to get a response on threads is to raise a hackle. You are sure to get one then! Nice job and thanks.
2015-4-4
drklion
Dangair Posted at 2015-4-5 01:38
Good! I'm glad I'm incorrect. I was seriously concerned about that and was thinking of hang testing  ...
Just to be clear: I have done a full throttle descent with a low battery charge and I had an issue with wobble, possibly a VRS and have done a full throttle descent with a charged battery at 90% and did not have any wobble, very stable.  It does not mean I feel the motors are ok in this maneuver.  I would have to do some more testing.  My concern was if the Inspire 1 was stable on the full throttle descent and it looks like the battery charge plays a big part on its stability.  So with that information I would venture to say that with a strong battery the Inspire 1 is making all the diagnostics and calculations for a safe descent and possibly refraining on stressing the motors as apposed to a weak battery.
2015-4-4
