Noise gimbal phantom 4 pro +
15811 184 2017-9-6
fansb4b8f76c
Hi,still haven,t received it yet,it’s nicky_doherty@hotmail.com.Thanks again.
2017-11-11
fansb4b8f76c
Hi Thor,there is an underscore between the y and the d on my account.Its very hard to see.Thanks
2017-11-11
Lapko33 9
Flight distance : 21522 ft
Hi. my P4P is making the noise as well. Also it is off center. The camera does not look straight ahead. Can I get the BETA sent to lapko33@yahoo.com.
Thanks
2017-11-12
9krpm
Flight distance : 46847 ft
Hi Thor. I just pmed you as well.  My P4P has similar problem with temporary help from IMU and Gimbal calibration but the noise came back.  I have been doing too many IMU and Gimbal calibration and would love to have a fix as well.
Thanks in advnace for your help.
2017-11-12
DJI Thor
Flight distance : 13602 ft
9krpm Posted at 2017-11-12 17:54
Hi, got your PM, the beta is available to your account now. Please check.
2017-11-13
DJI Thor
fansb4b8f76c Posted at 2017-11-11 07:11
Hi, I checked it and the beta should be available to your account for days. Had you received and updated it?
2017-11-13
DJI Thor
Lapko33 9 Posted at 2017-11-12 15:59
Hi. my P4P is making the noise as well. Also it is off center. The camera does not look straight ahead. Can I get the BETA sent to .
Thanks
Hi, the beta should available to your account now. Go ahead and check it.
2017-11-13
Lapko33 9
DJI Thor Posted at 2017-11-13 03:37
Hi. How do I check for the beta? Thanks. I am new to this. I turned everything on and connected my drone. It said checking for firmware but nothing else happened.
Thanks
2017-11-13
Julio Pacheco
Mexico
Please send me Beta firmware, masterk6@gmail.com
2017-11-13
DJI Thor
Got you PM again, I had reforwarded the beta to the account that you provided. See if you can receive it now.
2017-11-14
DJI Thor
Lapko33 9 Posted at 2017-11-13 05:37
Thanks
Lapko, please connect the drone to a PC, install DJI Assistant 2, log in the account that you provided above, then you can access it.
2017-11-14
DJI Thor
Julio Pacheco Posted at 2017-11-13 08:30
Yes, the beta is now available to you. Please check.
2017-11-14
fans637e492a
Flight distance : 669606 ft
Armenia
https://youtu.be/iAL3UdBtQV8
2017-11-24
fans637e492a
Armenia
How can i fix this noise
2017-11-24
fans637e492a
Armenia
Hello. My P4P is making the noise as well. Also it is off center. The camera does not look straight ahead. Can I get the BETA sent to dgayvo@gmail.com
Thanks
2017-11-24
KedDK
Flight distance : 1133038 ft
Denmark
DJI Thor Posted at 2017-11-14 01:39
As other has argued, in different threads, i simply don't understand why you (DJI) don't put those out for download in the download sections of the different models. Put it for download with a disclaimer that this is Beta and used on own responsibility and to transfer the flight log for developers to examine.
This would safe a lot of time and hassle for everyone.
2017-11-25
fans790cc8e9
Argentina
Hi, having the same problem. I'd like access to firmware beta please.
2017-11-27
fansa89b42d2
DJI Thor Posted at 2017-9-7 23:58
The beta should be available to your account, please check and update it. Let me know if you haven't received it.
Hi Dji Thor, I hope you could help me sort out my phantom 4 pro plus because the gimbal is noisy and the I take videos it’s shaky.  My previous one wasn’t like that before.
2017-11-29
fans28ec66fa
DJI Thor,
I also have the Phantom 4 Pro Gimbal noise/buzz problem. Can it get fixed with the beta update? Can you send the beta to tom.hegen@gmx.de thank you.
Hope that solves the problem.
2017-11-29
DJI Thor
fans637e492a Posted at 2017-11-24 14:38
P4p gimbal noise
Hi there, I had forwarded you the beta, please check and update it. Let me know if you haven't received it.
For the gimbal center issue, please try to calibrate the gimbal first, if it doesn't help, and it tilts to the right or left, you can try this: keep the drone power off, slightly wring the gimbal to the opposite direction for several times, or put the drone like the pic below then calibrate the gimbal. See if it helps. gimbal cali.png
2017-11-30
DJI Thor
fansa89b42d2 Posted at 2017-11-29 03:29
Hi, could you please leave me with your DJI account so I can forward a beta for you to test? Thanks.
2017-11-30
DJI Thor
fans28ec66fa Posted at 2017-11-29 17:35
DJI Thor,
I also have the Phantom 4 Pro Gimbal noise/buzz problem. Can it get fixed with the beta update? Can you send the beta to  thank you.
Yes, the beta is now available to your account, please check and update it. Thanks.
2017-11-30
DJI Thor
fans790cc8e9 Posted at 2017-11-27 19:01
Hi there, could you please PM me your DJI account? I would like to forward you the beta. Thanks.
2017-11-30
DJI Thor
KedDK Posted at 2017-11-25 01:55
KedDK, thank you for your concern, but now it can be only released manually by the engineers. It will be fixed in the coming firmware release. Appreciate your patience.
2017-11-30
Noisre
Albania
Hi. my P4P is making the noise as well. The camera does not look straight ahead. Can I get the BETA sent to
2017-11-30
DJI Thor
Noisre Posted at 2017-11-30 04:04
Yes, the beta is now available to your account, please check.
2017-12-1
fansbc6a57d4
Flight distance : 324642 ft
Hi, I am having the P4P Gimbal Noise & Vibration problem.  I have a job to fly on Monday morning, could you please send the Beta to john@elevated-solutions.net.  Thanks!
2017-12-1
DJI Thor
fansbc6a57d4 Posted at 2017-12-1 17:13
Hi, I am having the P4P Gimbal Noise & Vibration problem.  I have a job to fly on Monday morning, could you please send the Beta to .  Thanks!
Hi there, the beta is now available to your account, please check and update it.
2017-12-3
fansbc6a57d4
DJI Thor Posted at 2017-12-3 18:35
I was on the job this morning, first flight I was having the vibration problem...restarted and the beta update became available to install!  The update has corrected the high pitch vibration which seemed to be associated with the yaw motor.  No problems were noted for the remaining 5 flights of the day.  Thank you very much for your prompt response given my immediate need, it is very much appreciated. Cheers!
2017-12-4
DJI Thor
fansbc6a57d4 Posted at 2017-12-4 17:43
That's so inspired to hear the good news. Glad that the drone is working properly now. Hope your job goes smoothly.
2017-12-4
Adam Newcombe
Flight distance : 128967 ft
Hello,
Also, my P4P is making the noise gimbal noise as well.
The camera is at about a 40 degree angle, i would like to see if the BETA software will fix it as it may need to be sent in.
Can I get the BETA sent to info@aspectratio.com.au
Many Thanks
Adam
2017-12-9
Ian_Ph4P
Adam Newcombe Posted at 2017-12-9 15:47
Hello,
Hello Dji Thor,
Can you please send me the beta fimrware as well ?
My drone is a Phantom 4 PRO Plus.
Thank's a lot.
Ian
2017-12-10
fans637e492a
Armenia
After replacement YAW motor, YAW arm and flex Cabel ...camera look left or right ...can you help me resolve this problem ?
2017-12-10
Adam Newcombe
fans637e492a Posted at 2017-12-10 12:20
https://www.youtube.com/watch?v=HydvrgrtDSg
That is exactly what my P4Pro is doing. I have also installed new flex cable and replaced the roll arm. Hopefully there is a fix for the problem.
2017-12-10
Adam Newcombe
Hello,
Many Thanks
Adam
2017-12-11
DGAYVO
Armenia
Beta software dont fixed the problem !!!
2017-12-12
useruser
Flight distance : 580121 ft
Latvia
please send beta to me jankak@gmail.com
i today brought p4p, its not impresive
2017-12-14
DJI Thor
useruser Posted at 2017-12-14 10:54
Hi sir, the beta is now available to your account, please check and update it. Thank you.
2017-12-15
DJI Thor
Adam Newcombe Posted at 2017-12-11 17:45
Hello,
Hi Adam, the beta can be accessed from your account, please log in your account on the DJI GO 4 app or DJI Assistant 2 to check for update. Thank you.
2017-12-15
DJI Thor
Ian_Ph4P Posted at 2017-12-10 10:37
Hello Dji Thor,
Hi Ian, sorry for the late reply coz I haven't got the notification, could you please provide me with your DJI account so I can forward you the beta? Thank you.
2017-12-15
