Noise gimbal phantom 4 pro +
733331 733331 2017-9-6
DJI Thor
Flight distance : 13602 ft
fans637e492a Posted at 2017-12-10 12:20
After replacement YAW motor, YAW arm and flex Cabel ...camera look left or right ...can you help me resolve this problem ?
https://www.youtube.com/watch?v=HydvrgrtDSg
Hi sir, does the drone crash before? Please try to update the firmware and restart the drone for many times, if it doesn't help, you might need to send it in, please kindly contact support@dji.com for a further help.
2017-12-15
fansb4b8f76c
DJI Thor Posted at 2017-11-11 01:30
Hi, the beta should be available to your account, please check and update it.
Hi Thor,I installed beta and gimbal vibration stopped but I flew it for first time today and lots of problems.I lose connection to dji 4 after a short time,it is that bad that I don’t have enough time to do I use calibration before losing connection.Its stops recording on its own saying error or slow read write I think and it gives out wireless interference and poor channel quality which never happened before.I live in a very rural area.Can you help please
2017-12-16
matjonze
Flight distance : 55692 ft
Can I get the beta please, I have the whining gimbal and off centre camera issue - mat@jonzy.co.uk
Thanks
2017-12-16
DJI Thor
matjonze Posted at 2017-12-16 12:35
Thanks
Hi sir, the beta is now available to your account, please check and update it. See if it helps. Thanks.
2017-12-17
DJI Thor
fansb4b8f76c Posted at 2017-12-16 05:49
Hi Thor,I installed beta and gimbal vibration stopped but I flew it for first time today and lots of problems.I lose connection to dji 4 after a short time,it is that bad that I don’t have enough time to do I use calibration before losing connection.Its stops recording on its own saying error or slow read write I think and it gives out wireless interference and poor channel quality which never happened before.I live in a very rural area.Can you help please[view_image][view_image]
Hi sir, since the app had reminded the interference, have you tried to move it to another place and will the message persists? For your case, please try to check in another place first, choose a channel that has a less interference, and try to refresh the firmware of the drone and RC, then please try to switch the phone to Airplane Mode for testing. Besides, had you tried another phone to test this problem? Please try. See if it helps. Looking forward to your feedback.
2017-12-17
DJI Thor
Adam Newcombe Posted at 2017-12-9 15:47
Hello,
Also, my P4P is making the noise gimbal noise as well.
The camera is at about a 40 degree angle, i would like to see if the BETA software will fix it as it may need to be sent in.
Hi Adam, I got your PM, you mean the gimbal will tilt the Yaw for about 40 degrees and you had tried the suggestions on the forum, right? If yes, please try to put the camera to the opposite direction when the drone is powered off for several times. If it doesn't help, you might need to send it back. Please contact support@dji.com for a further help.
2017-12-19
Adam Newcombe
Flight distance : 128967 ft
DJI Thor Posted at 2017-12-19 06:09
Hi Adam, I got your PM, you mean the gimbal will tilt the Yaw for about 40 degrees and you had tried the suggestions on the forum, right? If yes, please try to put the camera to the opposite direction when the drone is powered off for several times. If it doesn't help, you might need to send it back. Please contact  for a further help.
Thanks for the reply. Yes I have tried what you suggested several times. I will most likely need to send in.
Thanks
Adam
2017-12-20
spikeuk76
Flight distance : 441138 ft
Hi DJI Thor,
I also have a noisy gimbal and calibration stops at 50%. Please can you add the beta firmware to my account. Many thanks
2017-12-21
ChuckNorris
DJI Thor i am having the same issue with the gimbal making noise and the calibration freezing at 50% after updating to the latest firmware v01.04.0602, can you please send the latest beta firmware to chucknorris_63@yahoo.com
2017-12-21
DJI Thor
Adam Newcombe Posted at 2017-12-20 23:31
Thanks
Adam
Not at all. Please kindly send it back and we will do the best to get it resolved.
2017-12-22
DJI Thor
spikeuk76 Posted at 2017-12-21 06:23
Hi DJI Thor,
Yes, of course, please PM me with your DJI account so I can help to forward the beta. Thanks.
2017-12-22
DJI Thor
ChuckNorris Posted at 2017-12-21 12:36
Hi Chuck, I had forwarded you the firmware. Please check and let me know if you can't find it.
2017-12-22
fans91bc2c5c
Flight distance : 138 ft
Can I have the firmware as well having the same issue with my gimbal. My dji account is jfernandes14@me.com
2017-12-22
DJI Thor
fans91bc2c5c Posted at 2017-12-22 18:02
Yes, the beta had forwarded, please check your account and see if it helps. Thank you.
2017-12-23
fansc84c9c3f
Bulgaria
Hello DJI Thoe, I have the same problem with gimble - shaking and strange noices. I've done firmware updates, gible calibration -failed 50%, IMU calibration all that several times but nothing worked.
That is my second Phantom 4 with that problem. First time i send it back to service in Germany but after a month the problem was not solved and they send me a new one. After 2 months the problem is back again.
Can you please send beta in order to try it before contact with the service or if you have other  recomendationq will be also helpful.
Thank you!
2018-1-4
fansc84c9c3f
Bulgaria
My email is uksstudio@gmail.com
Thank you again!
2018-1-4
fansf3a5fcb8
Flight distance : 457854 ft
Hello Dji Thor,
My account is
bcnvpoliti@gmail.com
could I please recieve the beta update to my accoount
Thank you
2018-1-18
Pardal-Voador
Flight distance : 989281 ft
Brazil
DJI Thor Posted at 2017-11-7 01:27
Hi there, please take a look at the gimbal, will it shake when it is on the ground? If yes, I will recommend updating to the beat version and see if it helps. Let us know if the issue persists, any video is highly appreciated. BTW, sometimes PM doesn't work good, so it would be great if you can reply me directly on the thread. Thank you for understanding.
Hi Thor,
My gimbal shakes when the aircraft is not on the ground..
What do you suggest?
Thanks
2018-1-18
DJI Thor
fansc84c9c3f Posted at 2018-1-4 10:41
My email is
Thank you again!
Hi there, may I know which drone you are using? The beta in this thread is for Phantom 4 Pro, please leave me your issue so I can help.
2018-1-20
DJI Thor
fansf3a5fcb8 Posted at 2018-1-18 04:29
Hello Dji Thor,
My account is
Hi, the gimbal noise issue had been optimized in the latest firmware, so if you are having the same issue, please ensure that you had updated to the latest firmware. Please let me know if it doesn't help, a video and the version info will be great for further help.
2018-1-20
DJI Thor
Pardal-Voador Posted at 2018-1-18 04:55
Hi Thor,
Just to verify, you mean the gimbal doesn't shake when the drone is on the ground, right? If so, if it is possible, check if it is the gimbal shakes or the whole drone does. Normally, you can try to calibrate the gimbal and IMU and test again. Looking forward to your feedback.
2018-1-20
Kreativos
Flight distance : 347123 ft
Mexico
I have a Phantom 4 Pro+ with the latest firmware installed and the gimbal makes a buzz sound any solution or beta? my email is ceballos_alejandro@hotmail.com
2018-1-21
Kreativos
Mexico
DJI Thor Posted at 2017-11-13 02:47
Hi, got your PM, the beta is available to your account now. Please check.
I have a Phantom 4 Pro+ with the latest firmware installed and the gimbal makes a buzz sound , can I get the beta? my account email is ceballos_alejandro@hotmail.com
2018-1-23
DJI Thor
Kreativos Posted at 2018-1-23 09:58
Hi, the latest firmware had resolved the gimbal noise issue for Phantom 4 Pro+, please make sure that your firmware is on V 01.05.0300, if it is not, please try to refresh the firmware via DJI Assistant 2, if it is, you might need to send the drone in. Please contact our support for a further help. http://www.dji.com/support
2018-2-2
djiuser_l2GDt0W45xIt
Flight distance : 418005 ft
Hello Thor,
just got my phantom 4 advance and i hear those gimbal noises and its vibrating... Please send me beta
dji acc: julius.pivarauskas@gmail.com
2018-2-15
ROKI
Croatia
How to zoom the camera on phantom 4 pro ?
2018-2-15
djiuser_l2GDt0W45xIt Posted at 2018-2-15 07:15
Hello Thor,
This is the noise the gimbal is making when camera is tilt down. Noise starts at only one angle - when camera looks down. Is it normal or should I start worrying?
2018-2-15
Pradipwb
Flight distance : 20545 ft
India
Hi I am having Phantom 4 Advance and the yaw motor is making noisy sound continuously.plz send beta update on pradipmaism@yahoo.co.in
2018-2-19
Sunil66466
India
DJI Thor Posted at 2017-9-8 00:45
Please let me know your DJI email account so I can help to push the beta, thank you.
impressionphotographyfrom@gmail.com
2018-3-14
DJI Thor
Hello Thor,
Hi there, the beta is forwarded, please check if you have received it.
2018-3-16
DJI Thor
Pradipwb Posted at 2018-2-19 21:10
Hi there, the beta has been forwarded, please check and update it.
2018-3-16
DJI Thor
Hi there, just to verify, are you using the Phantom 4 Pro, if yes, please update the firmware to the latest firmware version, the issue is resolved by the latest firmware.
2018-3-16
DJI Thor
ROKI Posted at 2018-2-15 08:56
Phantom 4 Pro does not support zooming. Thank you for your support.
2018-3-16
mrbill
Flight distance : 717100 ft
Hi dji Thor - can I get the beta firmware too please? Having similar issues - mrbillgill1@googlemail.com
2018-3-19
MattB1973
Hi DJI Thor, I am getting this Noise/Vibration. I have tried calibrating the Gimbal twice but still have this noise. Please may I try the Beta Firmware?
2018-4-22
noflyzone69
Flight distance : 240361 ft
What is going on DJI with the gimbal Vibrations???  Its alway something !!!  Mine has major vibration sound as well!
2018-4-22
MattB1973
MattB1973 Posted at 2018-4-22 07:42
matt1973bosworth@gmail.com
2018-4-28
mrbill
Hi DJI Thor - I’m on the latest software, but my gimbal makes the exact same whining sound. Can I please have the beta sent to mrbillgill1@googlemail.com
Many thanks
2018-4-29
fans566a241d
Tanzania
DJI Thor Posted at 2017-9-8 02:13
Had received your account and the beta should be available now, please check.
My phantom 4 pro is noisy when not flying, it gives a wierd noisy buzzing that hurts ears. Please tell me what to do?? I have read about installing the beta, how is that?? Watch the video of that sound
2018-5-19
fans566a241d
Tanzania
fans566a241d Posted at 2018-5-19 17:06
https://youtu.be/dfOkIVMfcQc
Watch that link of the noise that the phantom 4 pro is making, how can i solve this
2018-5-19
