Can you fly lower than the takeoff point
4134 13 2017-9-6
Pluggy
Flight distance : 33251 ft
This may be a silly question, so apologies in advance.
I have the Spark Combo and as a relatively new pilot, I'd like to try some cinematic shots in the Avon Gorge or Cheddar Gorge.
If I fly down into the gorge, will the Spark behave itself and return to home at the right altitude. If the altitude is above take off point, flying down into a gorge or lower than a mountain top should register a negative altitude.
Before I do something stupid, has anyone any experience please?
Cheers
Ian
2017-9-6
JMR58
Flight distance : 627966 ft
Belgium
Yes it does show a negative altitude in red, i often take off from a high sand dune to cruise over the sea without any problem on negative altitude, just keeping it in line of sight!Enjoy your Spark!
RTH works perfectly also, it rises up to the setted +altitude before returning home.
You will lose gps and wifi connection when you enter into a cave, so be careful...
2017-9-6
Charles Adams
Flight distance : 3821312 ft
I confirm that you can fly "lower" than takeoff point (or home point).  I flew up at my property a few weeks ago.  It's 40 acres on a mountainside.  I was taking off on the high points of my property to get the best views, and I was subsequently flying around the lower elevation portion of my property.  I had no issues, and the spark worked flawlessly.
2017-9-6
Sparky_17
Flight distance : 62349 ft
I agree, I tried the fly lower than take off point and it does fly well in '-' negative altitude ... enjoy and keep line of sight.
2017-9-6
NdFeB
Flight distance : 85013 ft
If you fly lower than home point how high it will fly on RTH?  30m from the point of activating RTH or 30m above home point altitude?
2017-9-6
hallmark007
Flight distance : 9827923 ft
Your RTH height is always set from your take off point, so if it's 30 metres altitude from take off then it will raise to this height before returning.
One word of warning before entering gorge make sure you have good gps, if you don't and haven't raised your Aircraft above 16 ft, before you start descending you run the risk of your aircraft descending all the way down into gorge.
2017-9-6
WayneMHK
Flight distance : 694728 ft
I had an issue with my P3A once where I was wanting to circle a POI that was lower than my TO point.  The app wanted me to have a minimum altitude before it would allow me to start and it was showing a negative.  Curious if that were true across platforms and intelligent flight modes.
2017-9-6
DJI Diana
Flight distance : 2408 ft
Yes, you can,  but to ensure the safety, I would recommend you keep it in your line of sight.
2017-9-7
DJI Diana
WayneMHK Posted at 2017-9-6 12:24
The minimum altitude of POI mode is 5 meters, you should make sure the altitude of the drone is within 5 m-500m.
2017-9-7
Pluggy
Thanks everyone. I went off to try it today, being one of the first flight friendly days of the year and lo and behold, Firmware Update required
2018-5-7
Jezmo
As the others above mentioned, yes it will be fine. I also think Diana's suggestion is good making sure to keep it in your line of sight. Sparky is an awesome little machine.
2018-5-7
ZarcTheSpark
Flight distance : 460676 ft
I have flown home and RTH many times with not issue.....
2018-5-7
Bing Err
Flight distance : 9249964 ft
YES.......
2018-5-7
JJBspark
Flight distance : 12225059 ft
Hi Pluggy,
Looking fwd to see that footage. (been there many years ago)
Be very very carefull ; when unexpected RTH pops-in its out of your control, if any obstacle is above your drone.....well, do not want to see that video!
Good luck.
Cheers
JJB
2018-5-7
