DJI Thor
Flight distance : 13602 ft
You can also try to check if the firmware needs to upgrade. Firstly, look at "About" on the general settings, if you can see the version of the drone, that means the RC is connecting with the drone, connect the RC WiFi with your mobile device, you should have the all connected normally. It will prompt you to upgrade if needed. Then you can try to adjust the antennas since if shows RC signal weak. If it still not worked, since the drone crashed before, like answers above, please send it in for repair. https://repair.dji.com/en/SelfRepair/Area
