Format SD card or just delete files?
11056 19 2017-9-7
george_007
Flight distance : 183045 ft
Sweden
Hi team!
When you need more space on your SD card do you format the card or just delete files?
Regards
Georg
2017-9-7
Blériot53
Flight distance : 6188465 ft
I have done both
2017-9-7
Lethal
Flight distance : 71096 ft
always format
2017-9-7
Satstream
Flight distance : 392024 ft
In the app, tap the faders under the record button. There is the function SD card format!
2017-9-7
Aardvark
Flight distance : 384432 ft
I use both, but probably format most often as the function can be easily accessed in DJI Go 4. The option to format also appears at the bottom of the 'Aircraft Status' list.
2017-9-7
Jan Jensen
Denmark
i allways just delete :-)
2017-9-7
pasaytenpete
Flight distance : 47346 ft
I just format as it's faster
2017-9-7
Gwen1405
Flight distance : 2543038 ft
Belgium
Format can give you error messages if your SD card contains bad "sectors"/areas, you'll probably get an error message during the format operation?!
But if you only delete files, you cannot see if your card is defect or not on some areas/sectors. And probably after, you can have som unreadable pictures or movies.
2017-9-7
rudyasho
Flight distance : 547320 ft
Indonesia
formatting. ..
2017-9-7
mtnlandpix
I always format.  Much simpler.
2017-9-7
RedHotPoker
Flight distance : 165105 ft
Always and only Format the card in the drone, not computer.
RedHotPoker
2017-9-7
DJI Susan
I would recommend to format the SD card in the drone as well.
2017-9-7
Geebax
Always format the card rather than deleting, and do it in the aircraft. DJI have a bunch of hidden folders on the card that get filled up with all sorts of files that may be useful to DJI, but otherwise just fill up your SD card. And the files and folders are hidden, you don't know they are there. A format takes care of all that for you.
2017-9-7
george_007
Sweden
Thanks guys! :-)
2017-9-8
fansfb99b3ba
Flight distance : 5220 ft
Hi guys Iam new here.  Can I ask what's the best sd card to use with a phantom 4. Thanks !
2017-9-17
george_007
Sweden
Since your question is off topic I suggest you start a new thread.
You're more likely to get an answer if you do.
Also, welcome to the forum. :-)
2017-9-17
RedHotPoker
fansfb99b3ba Posted at 2017-9-17 10:24
Buy one of adequate write speed with 64gb of recording space.  ;-)
RedHotPoker
2017-9-17
fans22489f76
India
Format the card:
There are various ways to format SD card:
First the normal method to format SD card and
Second the formatting SD card suing Disk management, below follow the steps:
  • First connect your SD card to      your Windows computer.
  • On your PC, click Start >      click on “This PC/My Computer”      and then select “Manage”.
  • On the left side, click on “Disk      Management”.
  • Now right click on the      Micro SD card> click on “Format” option> perform a quick      format.
Note: Above information is brought to you by: rescuedigitalmedia.com
2018-5-30
KedDK
Flight distance : 1133038 ft
Denmark
fans22489f76 Posted at 2018-5-30 05:00
Format the card:
Please go to hell with your spam and site Advertisements!
The only right way would be to format it in the aircraft.
2018-5-30
DVid
Ukraine
I'd suggest to format the SD card in the drone, so that it has appropriate files/folders structure. Also, formatting should help avoid file fragmentation.
2019-5-16
