fans06f3df75
Flight distance : 162408 ft
Christ Daniel Posted at 2017-9-8 11:31
My MVP comes with 16gb Sandisk and i plan to upgrade with the same brand with larger capacity, suddenly i found Extreme Pro, or Extreme Plus, or Extreme? Ultra Plus or Ultra? but Sandisk's website doesn't really explain the difference in these lines. But within each line there is a range of different read/write speeds from which to choose. any suggestion which one is good ?
DJI recommend Sandisk, Lexar, and Samsung. What is most important is that the card you buy must be:- microSDXC UHS-1 standard and at least Class 10 if you intend to record in 4K, this will be written on the packaging. Buy from a reputable retailer as this is a fundamental item. All the best. |
