P4p plus controller and windows 10 x64
891 4 2017-9-8
SM-17
Flight distance : 179288 ft
Hi all
Can someone please check if the plus controller with V01.02.01.00 firmware connects to assistant 2 in windows 10 (64bit) please?
Drone connects fine but not the controller
No missing/crashed/unknown drivers
Windows sees the GL300e controller and i can read internal and sd card storage
ADB recognises the controller
Controller reset to default
Assistant 2 V1.1.2-2 (tried older versions too)
Thanks
2017-9-8
DJI Susan
How about changing to another cable or PC? I would recommend the PC with windows 7 system.
2017-9-8
DentonPilot
Flight distance : 1009898 ft
No problems on Win 10 x64 on my end, RC's and Phantoms seen in DJI Assistant (have 3). Spark also has worked fine on same setup. Are you running Insider builds of Win10 by chance?
2017-9-8
SM-17
Malta
@DentonPilot
Did you try the p4p PLUS Controller?
Thanks
2017-9-9
KEDDK
Flight distance : 1133038 ft
Denmark
It does not work, Assistant 2 can only be used with the AC not the GL300E RC.
In some other thread the other day it soundedlike one could do a RC reset from Assistant 2, not sure it will do. See from post#3 here
2017-9-10
