depth perception
948 3 2017-9-8
DaViCToRR
why does everything seem sooooo much closer while in flight then it really is? is this a settings issue, or just something i need to get use to?. im not zoomed in at all...but things just seem overly closer then they should, whats going on?
2017-9-8
Asainz320
Flight distance : 1061594 ft
Are you coming from any drone or camera? What Im trying to ask is because maybe you're comparing it with the way it looks from a Phantom or a Gopro. The Mavic has a narrow field of view making things appear closer than a Phantom's camera or a Gopro.
2017-9-8
ImHereToCrash
Flight distance : 5381368 ft
the sensor size and the field of view of the mavic's camera... it effective is adding something like 1.45x zoom because of the smaller sensor and narrower FoV
2017-9-8
DJI Thor
Flight distance : 13602 ft
The FOV for Mavic is 78.8° 28 mm (35 mm format equivalent) f/2.2, if you have other lenses with greater FOV, you might see a big difference. But the Mavic Pro's lens is the most optimized version at present, can not be changed, and only support 2 times digital zoom.
2017-9-8
