Most prefer the DJI composite props over the carbon props for several reasons - better a prop to break than a motor or motor-mount to break is one, better a prop to break than a finger or facial bone to break is two - etc.
When it comes to replacement accessories, I generally stick with DJI products. Keep in mind, if the props are oversized, they could create too much torque on the motors. Wrong alignment and they could cause stress cracks. Non-DJI products, if used and damage results, can violate warranty or DJI coverage. Just something to think about.
Some say carbon fiber added more agility, while others say it added more noise, while others say they couldn't tell a difference. I think they look cool but ive heard many say they didn't see a difference in flight
That would depend on how well balanced they are, not on what they are made of.
Most of the carbon ones seem to be an identical shape to the standard ones so presumably they are just carbon-nylon composite instead of glass-nylon composite. They will be almost the same weight, almost the same balance, same aerodynamics, only difference is in the stiffness, flexibility isn't obviously a disadvantage for a photography drone, especially when they hit something!
i know for a fact not speculation that carbon fiber props on rc planes have more vibration.even when balanced with chadwich balance gear. wood props are the smoothest.the chadwic gear does dynamic balance,that is the best way to get the best balance possible.was a few years ago i tried this electronic balance.dont have access to balance gear now.i dont use carbon fiber props for safety reasons they tear up a lot before breaking.i like the dji originals props good luck.
i say stick to DJi products until something real comes out.. too many 3rd party prop makers fall short of claims. i wsh DJI would work with some company to produce carbon fiber props, properly made CF props have alot of advantages.. being less flexible means in same RPM range its pushing a lot more air down.. being one of the biggest differences.. othet thigns like it being harder then plastic means less likely to get damage from leaves and twigs... downside of CF is if they slam hard into a solid surface, bye bye props...
carbon fiber is very fragile.. they it can hold up to decent amount of abuse but slamming them into anything harder than it or something stops it completely and suddenly with all of its mass will damage the carbon fiber.. this could be you fly into a tree branch or hit a car or building or falls on street, the props can shatter in worst of cases or stress fracture..stress fractures can be more dangerious because they can be hidden and you may not see them and fail suddenly on next flight out without much reason it seems like.
ImHereToCrash Posted at 2017-9-10 10:43
ImHereToCrash Posted at 2017-9-10 11:09
Yeah but you seem to be implying that a composite prop would survive. Isn't it "bye bye props" regardless of what it's made of?
Mark The Droner Posted at 2017-9-10 12:08
Or a burnt out motor, when the prop gets caught in something, but stays true...
They may shatter, or dig in and let the motor smoke to death...
no, i have flown with cracked and chipped plastic props on my mavic pro, i would never do that with cracked or chipped carbon fiber props because that can suddenly let go once in the air. the plastic is more forgiving.
CF props do NOT vobrate more ... in fact once balanced and of good reputable brand - should be smoother in use.
BUT they are wasted on the P3 and such models as they only transfer Flight Controllers requirements to maintain flight. They are not called on to work like a 3D machine where extreme maneuvers are called for and CF props mainly developed for.
DJI composite props as stock are ideally suited and designed for the job.
As to which causes more damage ? Who cares when any prop of this size can sever fingers, carve large lumps out of any flesh that meets it ... kill / maim / injure ...
nigel i,ll have to agree to disagre.have you ever used any electronic dynamic balance equipment for any research to say that carbon fiber props are smoother?
No need ..... if you take any of todays modern 3D machines and stick a 'rough' prop on - you would very soon find out !! All props need to be balanced ... CF are no exception. Trouble is the ways to balance are many and some ways are not suited to some forms. If I observed a 'vibrating' CF prop - I would inspect it seriously for possible user error.
Vibration can be from many factors ... incorrect centering on shaft, unbalanced blades, bad balancing technique, bent shaft, worn motor bearings, loose motor mount or cracks ... the list goes on.
Seriously - CF props are primarily for use where high precision blade and stiffness called for - such as in large 3D model flying. When you punch out a 120cc gasoline SBach or Extra from a 3D move - you soon find out why CF props are used.
Why do you think Competition flyers of fixed wing and Helicopters use CF props / rotors ?
Any slight inbalance or 'roughness' as you imply - would soon be evident as vibration and eventual failure of the models structure. You only have to 'clip' a prop and literally have no visible damage - but next flight ... there it is.
The stock DJI props are basically GFN ... that's a composite of glass and nylon giving it stiffness and form .... commonly called Composite Props ... same as APC etc. Its a tough and durable format that satisfies most uses.
I really love the replies : any test data / research to support !! Love it !!
Go out on a flight line and 'listen' / 'feel' a model .... you soon tell who takes care with props and who doesn't !!
Example of my own model flown yesterday :
WOT4 aerobatics machine. 4250 650kv with 5S and 13x8E Composite prop.
Previously she was quite noisy when flown ...
But day before yesterday - I decided to check out and remedy if possible ... I cleaned and lubricated the bearings and swapped out to a new shaft. Checked prop balance - spot on ...
Flew her last night and the difference was remarkable ... you can hear for yourself ....
Near silent run ...
No need for " electronic dynamic balance equipment" to sort that one !! ....
RedHotPoker Posted at 2017-9-10 11:55
DJI makes the carbon fiber reinforced props... ;-)
https://m.dji.com/product/9450-carbon-fiber-self-tightening-rotor-black
Go buy you some. Haha
That's what I thought. DJI makes them. I be confused!
I don't fly the WOT4 Foamie ..... this is the third traditional wood WOT4 for me ... I had two back in the 1980's when they first appeared. I used to fly gliders and often was at same meetings as Chris Foss. I also flew power and is where I became friends with Phil Ramsay who kitted some absolute classic UK stuff ... such as My Skyleader Skymaster. I knew Kenny Binks as well .....
WOT4 with tuned pipe on an ST60 was my fun display machine !!
