kmarci94
Flight distance : 152723 ft
DJI Diana Posted at 2017-9-9 19:17
Just to verify, did you power the drone on? Besides, which Mirco USB port did you connect to? It should be connected to the Mirco USB port on the gimbal.
Well is solved the problem. First of all yes the rone was powered on and i used the usb of the drone but i figured it out that if i use the usb of the gimbal it works fine. So thank you for your help but the prombelm is solved already. |
