update firmware
1819 19 2017-9-9
fans04fe2b91
Flight distance : 373747 ft
update firmware
2017-9-9
Tahoe Ed
Flight distance : 41668330 ft
How may we help you?
2017-9-9
Did you encounter some problems during the firmware updating? Please post more details here for further assistance, thanks.
2017-9-9
geppypinoy56
So I been trying to update my spark remote for the past 3 days. Every time I try updating my remote the update would get stuck at 5%. After waiting for 15+ minutes I would just turn the remote off and restart my dji go 4 app. My spark and battery got updated fine. So what is wrong with my remote getting stuck at 5% every time I try updating it.
2017-9-9
geppypinoy56 Posted at 2017-9-9 23:11
What is your mobile device? If it is Android device, please downgrade the DJI Go 4 to previous version to update RC, or try iOS mobile device.
2017-9-10
Tahoe Ed
The update will only work on Wifi.  If you are using OTG then as recommended try an iOS device.
2017-9-10
fans648c4cdb
Hey! I can not update my AC since i got my mavic. It is working on the RC. The AC is still on 1.03.0300. now that i tried it again it wont take off anymore
2017-10-14
fans648c4cdb Posted at 2017-10-14 11:26
Did you update the firmware via DJI Assistant 2? May I have the error code?
2017-10-15
fans648c4cdb
Yes i did. But as i tried now to get the error code it worked i dont now what or if u did something but it worked so thank you very much
2017-10-15
fans1070167f
Flight distance : 362851 ft
Dominican Republic
Hello dears! I would like to know if they are ready to include the Spanish language DJI application. Otherwise we would like them to do so. Thank you!
2017-10-15
fans648c4cdb Posted at 2017-10-15 01:38
That's good to know, enjoy flying.
2017-10-15
fans1070167f Posted at 2017-10-15 12:25
Sorry that the APP doesn't support Spanish language at present, will feedback your request to our engineers for consideration.
2017-10-15
Oliver Ha
hey! after updating my firmware to the latest, i am now getting the gimbal motor overload warning and it dosent find its position anymore. i tried calabrating the IMU and gimbal.
2018-11-9
Oliver Ha
hey! i updated my mavic to the latest firmware. now i get the error message gimbal motor overload and it cant find the right position. i tried to calibrate the IMU and the gimbal without success. also tried down grading and upgrading the firmware again. any ideas? thx in advance
2018-11-9
Oliver Ha Posted at 11-9 14:55
Oliver, sorry for the troubles with the gimbal, may I verify if the drone encountered any crash or hard landing? Will the gimbal self-check normally after powering on? Can the Pitch axis be controlled by the RC?  Please check if there are any sand or obstacles in the gimbal, thank you.
2018-11-9
Oliver Ha
DJI Mindy Posted at 11-9 19:35
Oliver, sorry for the troubles with the gimbal, may I verify if the drone encountered any crash or hard landing? Will the gimbal self-check normally after powering on? Can the Pitch axis be controlled by the RC?  Please check if there is any sand or obstacles in the gimbal, thank you.
no Crash! the Problem occured while reboating from the Update. i can only control the pitch after imu calibration. automatic gimbal calibration stops with an error.
2018-11-10
Oliver Ha
could not find any dirt in it. gimbal is facing down after booting, and trys to again and again.
2018-11-10
Oliver Ha Posted at 11-10 02:30
Please check if the vibration absorbing board is mounted to all three of the hooks, here is the tutorial video for your reference:
If the issue persists, the drone will need to be sent in for further evaluation, please start a ticket here: https://repair.dji.com/repair/index
2018-11-10
Oliver Ha
DJI Mindy Posted at 11-10 03:00
https://www.youtube.com/watch?v=hnXekYjEJA8&t=3s
Hey! yes the it is mounted to all three hooks. i ll send it in. thanks for your help
2018-11-10
Oliver Ha Posted at 11-10 03:30
Alright, please post the case number here if you need any assistance during this process, we will do our best to help, thank you.
2018-11-11
