DroneFlying
Flight distance : 10774613 ft
Also are there any dont that should be listed.
Yes. The title of this thread is, "When to Panic?" and the answer is "never". In fact, staying calm is one of the more useful things you can do. One thing that helps with that is preparation, as in identifying the most likely scenarios and being ready to handle them. That seems to be what you're trying to do here so good for you.
For example restsrt of DJI GO ?
This is unlikely to help anything so it's not something I'd recommend. Even if the GO application stops working you still have control of the aircraft through the remote, and restarting the GO app is only going to be a distraction you don't need.
Sportmode ?
This might help in some circumstances, such as if you're executing a Litchi waypoint mission or fighting a strong wind (see below), but in general it's not going to be a solution if you're "losing control".
Turn of gps mode ? What does that mean ?
I don't know; where did you hear that from? Are you maybe thinking of / referring to the ATTI mode available on DJI's Phantoms? Because if so, it's provided by DJI with the Mavic.
Sys warning ?
I don't understand that one either.
Situations where you truly lose control of the Mavic are very rare. Possibly the most common one where that seems to happen is what I call BATTI mode, which can be triggered by taking off from a geomagnetically distorted location such as near steel or other ferrous metal. When that happens the Mavic seems to have something of a mind of its own, but the effect is only temporary and if you gain enough altitude to avoid crashing into anything it'll eventually recover and fly normally. So the best thing to do in that situation is gain altitude and try your best to negate the effects of BATTI.
Another common scenario is insufficient power to make it home, and the best thing to do in that situation is what pilots of "real" aircraft are trained to do: look for a good place to land that's close enough to reach. Granted, if you're flying over water there may not be a location where you won't lose the aircraft, but you can sometimes increase speed by reducing your altitude and, depending on how strong the wind is, you may be better off in Sport mode. |
