Cetacean
Flight distance : 2528264 ft
Aloha RK,
Sounds like we have some fruit juice here. Apples and oranges do not combine well naturally. Fortunately, you are dealing with Android and the warning indicated is for Android products. The speed data does get uploaded to the system prior to the flight. However, should the communication be cut, the autonomous function does not preserve the whole regimen. Kind of like RAM vs storage. RAM is volatile. Speed would be the RAM equivalent.
Unfortunately, Ground Station Pro is an iOS product. There is a significant problem that has kept the GS Pro out of the Android arena for as much as a year now. Is the speed issue the problem?
Most likely, there is no correlation between the speed limitation for Android and your concern. It is still most likely a "crap shoot."
Aloha and Drone On! |
