"Aircraft Disconnected" after firmware update
6432 10 2017-9-10
fans2ffbd8e2
I'm getting an "Aircraft Disconnected" error since doing the latest firmware upgrade to my Phantom 3 Pro aircraft and controller. Both updates seemed to go through normally, but now I can't connect to the aircraft. Any help would be much appreciated.
Thanks in advance.
2017-9-10
Tahoe Ed
Super Moderator
Flight distance : 41668330 ft
What phone/tablet are you using.  Are you on the latest App?  Anything change other than the firmware?
2017-9-10
LuckyShotPics
Tahoe Ed Posted at 2017-9-10 08:11
I've tried with my iPad mini and my iPhone 5s. Both running the latest version of DJI GO. Firmware was the only thing changed. Everything worked fine before updating it.
Any ideas?
2017-9-10
Tahoe Ed
Super Moderator
LuckyShotPics Posted at 2017-9-10 08:32
Any ideas?
Can you show me a screen shot of the camera screen and the About screen.  I am looking for the signal strength and the firmware versions.
2017-9-10
jwuliger
Flight distance : 327490 ft
Hello, I updated to the latest firmware and this morning my Mavic for the first time ever flew off on its own. It flew so far that I lost connection to it. I just bought the drone and with DJI Care Refresh. Yet I can't use it. How do you get support for something that you did not do? This was not me. I have two other DJI Drones and this has never happened. I can't even get the last known GPS coords because the drone disconnected from my iPad Pro.
Is there anything that can be done? This just not seem right.
Logs 1.zip
523.78 KB, Down times: 0
Drone Fy Off Logs
Logs 2.zip
529.04 KB, Down times: 0
Drone Fy Off Logs
2017-9-10
Tahoe Ed
Super Moderator
Did you find the Mavic using Find my Drone?  Please sync your flight logs to the cloud.  Then go to dji.com/support and open a case.  They will analyse the flight log and try to determine wihat happened.  Sorry for your loss.
2017-9-10
DJI Diana
Flight distance : 2408 ft
jwuliger Posted at 2017-9-10 15:19
Sorry for your loss, Have you done what Tahoe Ed suggested? You can refer to the link below to contact the Support. http://www.dji.com/support
2017-9-10
fans2799fd21
Flight distance : 885049 ft
I had the same problem.  This guy's fix worked for me.
2017-10-31
fansf7de602d
Flight distance : 27608 ft
fans2799fd21 Posted at 2017-10-31 13:24
I had the same problem.  This guy's fix worked for me.  https://youtu.be/pv-pxg9SCek?t=1m55s
Cool... this worked a treat!!! Thanks Man
2018-2-17
HOOM
Iran
Hello
my problem is  "Aircraft Disconnected" error since doing the latest firmware upgrade to my Phantom 3 Pro aircraft and controller. Both updates seemed to go through normally, but now I can't connect to the aircraft. please help me to reconnect
Thanks alot
2018-5-5
DJI_ALEX
Flight distance : 1733383 ft
https://forum.dji.com/forum.php? ... D534%26typeid%3D534
2018-8-25
