hallmark007
Flight distance : 10017858 ft
bassistas Posted at 2017-9-10 15:41
it is still fully functional. I have done an IMU , compass and gimbal calibration after the crash. It seems to be working like it should, its stable in the air and the camera/gimbal works good except some minor gimbal shake sometimes which was there also before the crash and because I am using the drone very often for my work I couldnt wait 1 month for an RMA. So nothing changed as I said except some scuffs on the edges of the landing legs and and some very minor on the edges near the motors. The height it fell was about 3 to 4 meteres from the ground and because it fell inside the tree foliage it somewhat reduced the drop speed
This might help to avoid same happening in the future.
start AC leave until you receive enough gps lock ,
Raise AC to height of 8ft
Hover for 20 seconds
Fly forward 2ft
Backward 2ft
Left 2ft
Right 2ft
Up 2ft
Down 2ft
Yaw left
Yaw right
Each time returning to hover position
If you have a good horizontal each time, you will then know you have good GPS good IMU and good Compass, and your ready to fly.
This exercise takes less than 2 minutes and is worthwhile doing before every flight, |
