Asainz320
Flight distance : 1061594 ft
Great work! After seeing your three videos, these are my comments for better results:
- Pan slowly. When panning left and right move slowly so the viewer has time to see and take in the scenery.
- Keep an eye on your exposure. If you want you can keep your Histogram open to tell you how you're exposure is doing while you shoot. You can also use the Exposure Peaking mode to tell you what is being burned due to over exposure.
- It seems that you're using D-Log. If you use D-Log it would be to do color correction later. If you're not doing any post editing on the footage then I suggest using other modes like Vivid or Normal. You will get better colors and contrast than just leaving D-Log unedited.
I hope this helps you a bit to get better |
