Genghis9
Nigel_ Posted at 2017-9-13 03:01
If you are flying your drone in the Mach Loop area then please check the RAF low flying timetable and don't think of flying when they are active. "high" sub-sonic means that you don't hear them coming until a few seconds before they arrive, I know from experience that 100ft with 2 seconds warning does not give you time to think about getting out of the way even when you are not flying a drone, and 100ft with a 60ft wingspan means the wingtip can be below tree height!
UK low flying timetable: https://www.gov.uk/government/publications/operational-low-flying-training-timetable
I'm in awe of you very smart people and your sophisticated cameras.
While I'm amused and impressed by this debate, I can assure everyone that those Mudhens were no lower than 500' AGL and it was more like 1000' to 1500' AGL.
Also, I know it sounds really really cool to talk about aircraft flying at 100' AGL and even getting some cool pixs of them that low. However, all should understand that flying that low at near Mach snot is extremely demanding on the pilot's attention. Matter of fact that is all he can think about at that altitude is not hitting the ground, nothing else, not navigating, not weapons employment, not defensive maneuvers/actions, hell even changing a radio channel is a life & death challenge, nothing but hoping you don't get a twitch that causes you to impact the ground. At those speeds of about .9M, then at 100' AGL the time to impact with just 1 degree pitch down is measured in single digit seconds (~6.7s). So, they fly that low at times no doubt about it, but they don't stay there for extended periods and even less so in terrain that is undulating.
Nigel is correct, short of a special circumstance all military low level routes are published/established along with their altitude blocks, typically surface to X. Therefore, it is best you know where these routes are and avoid them like the plague if you intend to fly your UAV there. |
