next week go bali. must download map?
1102 16 2017-9-11
bernardren07
Flight distance : 48504 ft
Singapore
Hi. Next week i go bali. When i open my app DJI GO 4 and saw map offline. I choose indonesia map offline and need to download all map only indonesia before i go there? or no need? Just use hotspot wifi and auto search map? I afraid that if go there and cannot recognised the place when use mavic pro.
2017-9-11
DJI Thor
Flight distance : 13602 ft
I think it would be better if you downloaded the offline map on DJI GO 4 app previously. Then check it on the app. That might be an insurance.
2017-9-11
TJAUS
Flight distance : 16683 ft
DJI Thor Posted at 2017-9-11 20:34
Hi Thor,
How do you download the maps for offline use in DJI GO 4? (or DJI GO for that matter)
Cheers,
TJ
2017-9-11
travelrikk
Flight distance : 21877946 ft
Malta
TJAUS Posted at 2017-9-11 23:01
Hi Thor,
Cheers,
Following..
2017-9-12
DJI Diana
Flight distance : 2408 ft
Hi Thor,
Cheers,
Are you using an Android device? Launch the APP, click the icon in the top right corner of the homepage, you'll see the Offline Map.
2017-9-12
bernardren07
Singapore
ok thank you so much
2017-9-12
TJAUS
DJI Diana Posted at 2017-9-12 00:32
Hi Diana,
No, i'm using an iPhone 6 that is now purely used for Mavic. No sim card so i need to download maps before i leave my home wi-fi I assume. Is it the same process for iOS?
2017-9-12
VoDoXuS
Flight distance : 88619 ft
Singapore
If you have Wifi hotspot where u fly, itll just load the map. You guys understand that even without a map you can still fly right? You just cant see a map.
I used a crystalsky and was just in Ubud. Downloaded offline maps coz I didnt know if I would be near wifi.
Works fine.
Heres a video.
2017-9-12
bernardren07
Singapore
VoDoXuS Posted at 2017-9-12 22:51
wow nice ok. u used video PAL? look like little video freezing when fly.
2017-9-13
VoDoXuS
Singapore
bernardren07 Posted at 2017-9-13 03:44
Im not sure...I never really thought PAL/NTSC would make a difference in the video smoothness. Its an old TV issue, but not really anymore
2017-9-13
Ex Machina
Flight distance : 1806362 ft
Wow, some gorgeous shots there. Dug the music as well.
2017-9-13
Ex Machina
TJAUS Posted at 2017-9-12 20:47
Hi Diana,
It's the same process for iOS in that you navigatge to the intended flight area while connected to the internet, but I find I never use the map, preferring the radar-like view. Have fun -- I'm quite jealous. ;)
2017-9-13
DJI Thor
Hi Diana,
Nope, iOS devices don't have the offline map to download. You can try to cache the map when you have WiFi resource. This is the route: enable "Cache Map in the Background", navigate the map to the destination you would go, when the names show, the cache finished. You can shut down the internet and check the map again.
2017-9-14
DJI Thor
Thanks for your feedback. And plus, amazing spot and great video there.
2017-9-14
bernardren07
Singapore
VoDoXuS Posted at 2017-9-13 19:10
only i know ntsc is much smooth. ntsc got 30fps. pal only 24fps and 25fps. you try switch to ntsc with 30fps and see. me current used ntsc 30fps. you can try and see then send video here. haha
2017-9-14
DJI Diana
Hi Diana,
Nope, the process is different for iOS, Thor replied you with the process for iOS in the post 13#.
2017-9-14
VoDoXuS
Singapore
Ex Machina Posted at 2017-9-13 20:52
Thanks. Totally not enough footage though haha
2017-9-17
