Paul_IA
Flight distance : 4959019 ft
Q1: Yes, GPS is used to calculate the distance between the MP and the Home Point
Q2: Yes. If the RC looses connection, the MP will return home on it's own, assuming you have properly set the home point prior to take off and specified this behavior in the configuration. RTH is not the only option when signal loss occurs, but it's the default one unless you change it. |
