Max Flight Distance
ourfrank34
Flight distance : 105430 ft
Hi there,
Can anyone explain Max Flight distance?
In DJI Go app you can switch button to enable max flight distance. However, on the line below is says set Max Flight distance (15m-500m). Does this mean the max distance I can fly away from the home point is 500m??
If I turn off max Flight distance does this mean I can fly in excess if 500m?
Appreciate a steer on this please :-)
2017-9-11
Capt Whitefoot
Yes, under settings you can adjust your "max" distance.  I set mine to about 2000m because in my city I start losing reception at about 1800.
2017-9-11
DJI Susan
Yes, you can disable the max flight distance to get farther distance.
2017-9-11
KEDDK
Flight distance : 1133038 ft
Denmark
To me it seem that you mix up max distance with max altitude (height).
The altitude can be set to max 500m.
2017-9-12
ourfrank34
KEDDK Posted at 2017-9-12 00:07
Thanks! I tried this in my setting controller, but today Max distance warning after 50m and a max altitude waring at 30m.  Not sure why...
2017-9-15
ourfrank34
I curently have my max flight altitude at 120m and max flight distance at 500m but still get max warnings at 50m distance and 30m height. I cannot go any further...why?
2017-9-15
ourfrank34
I currently have my max flight altitude at 120m and max flight distance at 500m but still get max warnings at 50m distance and 30m height. I cannot go any further...why?
2017-9-15
ourfrank34
DJI Susan Posted at 2017-9-11 19:08
Thanks! I currently have my max flight altitude at 120m and max flight distance at 500m but still get maximum distance warnings at 50m distance and 30m height. I cannot go any further...why? I have checked this a few times and during flight also.
2017-9-15
BagoDJIoperator
Flight distance : 1077608 ft
I have gotten pass 2000ft and continued.
2017-9-15
DJI Susan
ourfrank34 Posted at 2017-9-15 13:05
Please try to re-install your APP and login your DJI account to check again. I would recommend to restart the app and aircraft if you changed to another battery.
2017-9-16
KEDDK
Denmark
ourfrank34 Posted at 2017-9-15 12:52
That sounds like the need to login in the app when connected to the big net, eventually logout and in again, after this don't logout again. Also i have experienced that pressing exit when in my profile in the controller/app it does a logout.
Another issue would be if you are in what DJI has stated to be a no flight zone, checkout on http://www.dji.com/flysafe/geo-map
2017-9-16
hallmark007
Flight distance : 9827923 ft
ourfrank34 Posted at 2017-9-15 12:58
In order to access max distance you need to turn off max distance button, i.e. It should be clear not green, I don't know why it's like this it's a bit of a misnomer.
2017-9-16
ourfrank34
KEDDK Posted at 2017-9-16 00:46
Thanks I will try the login process. Was in the middle of the countryside, so definitely clear to fly ;-)
2017-9-16
ourfrank34
DJI Susan Posted at 2017-9-16 00:45
Thanks Susan. Lets hope that works.
2017-9-16
DJI Susan
ourfrank34 Posted at 2017-9-16 10:03
My pleasure. Should there is any further questions, please come back to us.
2017-9-20
damien be
how did you go to 2000m, i miss the signal at 700m in a open field...
What channel (wifi) did you used?
2017-10-9
KedDK
Denmark
BagoDJIoperator Posted at 2017-9-15 14:41
Hi
Check the post above :-)
I could wonder the same but guess you have better transmission power in us.
2017-10-15
ACW
Flight distance : 13877205 ft
Sounds like you are in a NFZ and have a geo fence restriction or you need to update the NFZ database when you first turn on the drone and ensure that you have all FW up to date.
2017-10-15
BagoDJIoperator
damien be Posted at 2017-10-9 11:22
That’s weird how are your antennas pointed?
2017-10-16
DJI Diana
Flight distance : 2408 ft
Which the model number of your drone, P3 SE or P4P?
2017-10-16
