Firmware update problems
2041 33 2017-9-11
SuperSebaS55
Flight distance : 76598 ft
Argentina
Hello everyone. I'm trying to upgrade my mavic pro firmware 1.03.400 to version 1.03.1000. I have tried every possible way. With the Mobile, with the remote control, with Dji Assitant 2 and I always get error in the update.
Probe with 2 computers, with 2 USB cables and it is impossible. There is always an error in the update. I have tried more than 20 times, with 3 different batteries. I need you to assist me with a solution, thank you very much
2017-9-11
Jdove
Flight distance : 8691 ft
I've got a similar problem but I've only tried about 4 times. Still using up batteries for this 30 minute upgrade. Is there a problem with some of the Drones?
2017-9-11
Sir Francis
Flight distance : 489029 ft
Puerto Rico
ive got the same problem.  i the my drone wont fly cause of incompatible versions.  ive tried downgrading and upgrading with the same results...error  WHAT CAN I DO?!?!?
2017-9-11
DJI Thor
Flight distance : 13602 ft
Did you get any error code when it failed to upgrade? If yes, what is that?
2017-9-11
SuperSebaS55
Argentina
Since I bought the drone 3 weeks ago, I could never blow it. I always got the error of the incompatibility of the versions
2017-9-11
DJI Thor
Jdove Posted at 2017-9-11 15:24
Please refer to my answer above and name it if you got the error message. And please kindly keep the power beyond 50% when doing an upgrading.
2017-9-11
SuperSebaS55
Argentina
Yes, 0x020103 or similar. I will try again
2017-9-11
DJI Thor
Sir Francis Posted at 2017-9-11 15:45
Please kindly refer to my answer above. Will do the best to help things out. Thanks.
2017-9-11
SuperSebaS55
Argentina
DJI Thor Posted at 2017-9-11 18:19
0x20106 The number or fail
2017-9-12
fans4c6a9621
Flight distance : 794 ft
Trying to update it been a month so far thinking about sending it back
2017-9-12
SuperSebaS55
Argentina
fans4c6a9621 Posted at 2017-9-12 10:33
I'm thinking the same thing. It really is a frustrating situation.
2017-9-12
Lara
Slovenia
I have the exact same problem! Giving up soon grr
2017-9-12
DJI Thor
SuperSebaS55 Posted at 2017-9-12 10:23
Please leave me your DJI account, I'll help to forward a beta to your account and you need to upgrade to it first and then upgrade to the latest version.
2017-9-14
DJI Thor
Please help to name the error code, we got a temporary solution for a certain error. Thank you so much.
2017-9-14
DJI Thor
Lara Posted at 2017-9-12 13:31
Please refer to my reply on 14#, thanks.
2017-9-14
SuperSebaS55
Argentina
DJI Thor Posted at 2017-9-14 02:20
ssebas2011@gmail.com
2017-9-14
SuperSebaS55
Argentina
DJI Thor Posted at 2017-9-14 02:22
Hi, Can you do it before the weekend?
Thanks
2017-9-15
DJI Diana
Flight distance : 2408 ft
SuperSebaS55 Posted at 2017-9-15 04:36
Thanks
Sure, done, Please refer to the steps below to upgrade it via the DJI Assistant 2 again.
1. Log into your DJI account.
2.Upgrade the firmware V1.3.8.10 or V1.3.8.11. or V1.3.8.13
3. Once it's done, please press the "Record" button on RC and make sure it's recording, then start to upgrade firmware to the latest one, it will be working.
2017-9-15
Lurov2588
Peru
Hi i 've got a similar problem. I could update the RC but when i try to update the ac my pc doesn't recognize the device. I follow all the instructions of the videos but nothing happens.  I disabled the drivers signature of windows 10 and again nothing. Please i need any help because i work with the drone.
2017-9-15
Leonard91
Malaysia
Hi, I've encounter the error as well. My DJI ID wenfu.c@outlook.com.  The error code is 0X020106
2017-9-15
Jenee 2
Flight distance : 7852129 ft
Lurov2588 Posted at 2017-9-15 21:26
Are you using the usb cable that came with your Mavic? You are removing the gimbal clamp and turning the Mavic on? After updating the RC, you should close the Assistant 2 software and then reopen it again after attaching the Mavic and turning it on.
2017-9-15
Lurov2588
Peru
Jenee 2 Posted at 2017-9-15 21:55
yes, i used the cable that came with the mavic and used others. I removed the gimbal too. I've tried the updating in diferents days.
2017-9-15
Jenee 2
Lurov2588 Posted at 2017-9-15 22:07
What firmware version is your Mavic on?
2017-9-15
Lurov2588
Peru
Jenee 2 Posted at 2017-9-15 22:23
i think is v01.03.0900  the last version before the version v01.03.1. Seeing some post is that the problem is not connecting the rc with ac but as my pc doesn't recognize the ac I can't update it to the last version
2017-9-15
Jenee 2
Lurov2588 Posted at 2017-9-15 22:32
If you turn your RC on and then turn the Mavic on, do you get a firmware mismatch notice? Also in the settings menu go to About at the bottom and it will tell you what versions the RC and Mavic are on.
2017-9-15
Lurov2588
Peru
nothing happens, the control fails to connect with the mavic, the mavic the yellow led flashes and about I have this, as it does not connect the mavic does not give information
2017-9-15
Lurov2588
Peru
Screenshot
screenshot
screenshot
2017-9-15
DJI Thor
Leonard91 Posted at 2017-9-15 21:53
Received your account and forwarded to the engineers to release the beta. Please check your account later and follow the steps Diana mentioned on 18#. Thank you.
2017-9-16
DJI Thor
Had you tried to relink the drone and RC? Please refer to the tutorial below and try. Besides, could the PC recognize the drone? I mean could you read the files of the drone on the PC? If you could, then it might be the Driver of DJI Assistant 2 wasn't installed properly. Try to reinstall it or update it on another PC. If you couldn't view the files, then it could be the cable's fault, change another cable.
2017-9-16
Leonard91
Malaysia
DJI Thor Posted at 2017-9-16 00:53
Hi. Thanks again. Had succecssfully updated.
2017-9-16
sova
getting errors. mismatch. mavic at 400, battery and rc at 1000.
I would really like to make the drone fly again.
2017-9-16
DJI Thor
sova Posted at 2017-9-16 14:49
Please try to upgrade via DJI Assistant 2 again, it will help.
2017-9-19
DJI Thor
Leonard91 Posted at 2017-9-16 03:29
It's my pleasure, should you have any further questions, please feel free to contact us at any time, we're glad to help.
2017-9-19
HereForTheBeer
Flight distance : 5381368 ft
i tried to do the update via dji assistant 2 on PC, no failure but it stalled out on 100% downloaded for 30 minutes..it didn't switch to installing anything... i decided to cancel it and use my iPad mini 2 to run the update, which it complete no problem.
so there is something going on with dji assistant 2 on PC...
2017-9-19
