DJI Susan
djiuser_hkRfWXX Posted at 2017-9-12 21:20
Hi Thanks i am still not getting anywhere even with mobile data it still trys to connect to the internet it gives me no options to use mobile data? But i found this but i didnt think it could be done with the P3S..
3. Attach the lightning cable from the transmitter to your device. (The "Camera" tab will now be blue as your device is plugged into the transmitter and detected.?
3. Attach the lightning cable from the transmitter to your iOS device. (The "Camera" tab will now be blue as your device is plugged into the transmitter and detected.)
There are several differences:
1. For P3S, the mobile and controller connected via WiFi. And P3P connected via USB cable.
2. As for Step 10, it requires to bind with your DJI account, please input your email address, disable the RC WiFi, and enable the home WiFi/mobile internet to activate. It is very important.
It still no helps, please change another recommended to try. I would recommend to switch to IOS devices for double check. |
